Reign E+ 2022
Anyone else suffering from badly resonating XT brakes on the E+1? Screeches and resonates so bad you have to let go the brake and reapply.
I've changed the pads, realigned the caliper and axle, use brake cleaner on the discs (they never got contaminated), check the bolts and the disc is not warped
Help, not sure what else I can do!
Have you kept the OEM shimano rotors?? They are an embarrassment for a bike of that price to be honest. I swapped them out first thing. no noise except in the wet as usual.
which rotors do you recommend? Thanks in advance.
I've just ordered some Ice tech rotors and see if they improve things. Local bike shop suggested that if that doesn't help post mount might need to be refaced.
Any one here dropped Chainring size? thinking of fitting a 32T instead of a 36. I am surrounded by long climbs, and also looking to better match some mates who are,nt E-powered yet.
does it affec the software does it need any update for the power meter
. or can I swap just like a normal bike.
I ordered some similar Shimano replacements but couldn't use them in the back because the speed sensor wont stay in unless you epoxy it.
Yes. I have. Which end? I get a bit of this on my E+1 now at the rear where I still have a standard shimano 203mm disc. I get it minimally on the front where I have a Magura 220 disc. I have a 220 for the rear also but not fitted yet.
I am not totally convinced that it is the fault of the solid disc on the rear though. I find the 4 pot shimano brakes very sensitive to set-up and the metal pads very prone to this. Sounds like you already covered alignment. I find that alignment takes more than just aligning the caliper with the disc. If the pads are contacting the disc at exactly the same time with both pistons then that helps for sure. I am still running the metal pads that my bike came with and I do get occasional resonating. I can live with it but will change the pads when these are done.
I had this issue on my wifes Trek Rail. I could not stop the resonance with shimano metal pads at the rear. I swapped the disc but the ultimate fix was to use resin pads. Fixed completely.
On the front for me. Plan of action is as follows:
Realign the caliper once again.
If that fails fit a new ice tech rotor.
If that fails fit resin pads.
If that fails get the mounts refaced.
I'll keep you posted as to which of the above solves it.
Hi, yes i did and it is plug and play. But you have to remove the Spider to mount the 32t Chainring.
I am sure someone posted something on here about the bosch disc mounted magnet working just fine. I will look into that for when I swap the rear
Today I was supposed to take delivery of my new Reign E+2. The LBS called to tell my the paint is scratched and off at the seat tube (see pic below).
I told them I'm not taking the bike for now, call Giant and see what they have to say.
What would you do guys if you were me?
LBS said we could fix it with some careful paint job by a pro and probably Giant will offer some small discount.
Otherwise if I do a warranty claim, and ask for a new bike, who knows for how many months I will have to wait ....
Opinions ???
Opinions ???
Aluminum frame not carbon, I would see what kind of discount they offer. We are all going to have damaged paint at one point.
Opinions ???
I'd push for a discount of £100. It would only get scratched anyway being a MTB.
Opinions ???
Touch up paint + discount sounds good 👍... if you want to ride it this season 😫
Opinions ???
I'd ask for a discount and just put paint over it or add a frame protective patch. Its going got get worse marks than that in the future!
I get this too - worse on the back. Swapped the back rotor for an old Hope I had and instantly fixed. Resin pads made almost no difference. Thinking of putting a decent 220 on the front - maybe SRAM but wont be Shimano.
i put on a Praxis 32, the smallest they make and that can be fittted. however, i also swapped to a 10-45 cassette and short cage rear mech, so the gearing is essentially the same. i love it. it makes for a smaller drivetrain, and the rear mech is 30mm shorter, so on the small rear wheel it gives much more clearance. there are many steep climbs where i ride and i don't find any need for lower gearing, personally.
How is the clearance to the chainstay on the rear?
i also have these big Galfers and it's fine. i think they are slightly quieter in general, but it does depend somewhat on the moisture and dirt spray, speed, etc. sometimes at slower speed the first bite can still produce noise and vibration during wet rides. one thing to keep in mind is that huge rotors like this take longer to heat up before they have big power. slow speed riding in the wet (which is where i live, with no spring in sight yet, but that's another very grumpy story....) has no real advantage. but when i get a sustained descent where speeds increase and i'm on the brakes more, they are awesome. i'm also a larger rider at about 230 pounds fully outfitted to ride with pack. this bike excels at this kind of riding with it's suspension horsepower, geo and big brakes. love it.
ironically, i'm about to head out for a ride in cold, wet, slow technical trails, so i expect a bunch of honking and vibration from my massive brakes on my downhill sled of an emtb. nice thing is, the bike can really do anything well, so i'm happy either way.
Please show us a picture of your setup, sounds interesting 🤓
doesn't look much different. i would guess that if it wasn't pointed out, it would never be noticed. the trail photo is an example of an average stretch of local trails. everything is trying to grab your drivetrain. it would be rare to make it through an entire ride without stopping to remove vegetation from my drivetrain at least once. had to do so 3 times today.
Put the front mudguard on the rear. It protects the suspension and the link better.
How loud does the engine clutch make? This engine is an annoying whine when it drives close to 25km / h. Should take a video next time I ride a bike.
I'm wondering about the automatic setting for engine assistance. It can only drive on the road, makes sudden accelerations. It feels like it has full power on it with an easy, smooth ride
I am also disappointed with how heavy the bike is pedaling without assistance. Is this a yamaha feature? Otherwise, I like the bike, is really fast on the trail. The pedals easily catch on the ground but it should be repaired when I lift the stern higher.
I used this same setup on my Trance last summer and loved its performance. I'd like the setup even more, if the cassette was all steel.
I used this same setup on my Trance last summer and loved its performance. I'd like the this setup even more, if the cassette was all steel.
i'm not sure why they don't come this way stock. it's not like you can overpower the bike in the smallest cogs with the stock 36 tooth ring, you would be going well over the restricted limit. once i hit the limiter, which is only on gravel access roads, i have no desire to try and out work the system. and no one is ever going this fast down hill and pedalling. IMO the set up i now have is perfect for an emtb.
    Join 43,253
