thaeber
The important question is does it support boost, because only that funtion allowing to ride faster than dog wandering on street.
Boost works not so bad, at least it „is”. Other brand engines are ending on 25 and thats it.
I was thinking for my M600 but fair point..
The M500 I rode wasn’t bad, but it definitely felt odd dropping assist, was smooth enough, just ‘that’s it?’
If that limit cant be bypassed, yet another use if someone does a DIY HMI/controls - getting to boost should be a single button..
Hi, i have a question - how you noticed the M500 have problem with overheating? Some error, power degradation, or just was hot?but the overheating is a big problem,
Never had that, even at steepest and longest climbs….Wenn ride uphill for about 5-10 min, Motor temperature starts to rise to the point where you cannot touch it, otherwise you will burn your fingers, and the performance also begins to decrease as if you are on the level 2, but in fact it is on the level 5.
So I have to stop until the motor cools down and then get back on the bike to get the full torque.
No errors
(Weather temperature around 20-25)
2. Where can I buy an e-bike frame? (Most here in the forum have Dengfu E10 , but I didn't find it, there is E-05 What's the difference?
3. Is the process of building a bike difficult and is there a clear and detailed explanation somewhere?
Was the power consumption constant above 550W?Never had that, even at steepest and longest climbs….
If You ride 1h, its 550 Wh!Was the power consumption constant above 550W?
You got me wrong! I'm talking about watts, not watt-hours. There is a difference between them.If You ride 1h, its 550 Wh!![]()
On what firmware are you?You got me wrong! I'm talking about watts, not watt-hours. There is a difference between them.
During heavy load on the motor the amp goes up to 11 this means:
11 × 48 = 528 watt
When this amount of watts is consumed for 5-10 minutes, the motor overheats and its performance decreases, at least that's what happens with my engine.
I use 12A Frimware (CRX10NC4812i142015.5)On what firmware are you?
i think i have similar observations but i had no clue because i observed this rarely.
At least we know we can push amps and engine have temp protection - thats good news.
Wiche Dengfu frame size should i choose?
S 15"
M 17"
L 19"
Is matt or glossy better?
I'm 177 cm tall
Many thanks!Probably the Medium. I’m 183cm with a Medium frame. Realistically I could have gone Large but wanted my wife to occasionally use it. YMMV as usual, but at 177cm I’d wager a Med frame E10 would fit well.
Matte finish will pick up and ‘hold’ dirt easier, while the gloss should clean up easier. Personal choice, really.
Exactly when the motor heats up, the protection works to not allow the current draw to rise. This would also prevent more heat.
But this is my problem with this engine, that it cannot withstand working under high pressure for a long time, but i think this problem has been solved with the new motor M510.
I‘m 183 cm and have a L frame. Perfect for me. I would choose M frame for You!Wiche Dengfu frame size should i choose?
S 15"
M 17"
L 19"
I'm 177 cm tall
Thanks for the great tips!I’m also 183cm and went with a Large E10 (still on its way). Also gloss finish, as I’m happy not to need to paint at the start. (I have also seen on the forums a few people 183+ cm who are happy with XL size.)
To order, compile list of what you want to order (frame, motor, battery, wheelset, other parts…) and email Melody ([email protected]) for quote. After confirming shipping etc., you can then pay with PayPal.
The most important thing is to do some deep research through various threads here covering other people’s builds, and compile list of what you need. It will be a much smoother ordering process if you are 99% sure of what you want to order from Dengfu.![]()
Thanks, I think I'll choose the medium size.I‘m 183 cm and have a L frame. Perfect for me. I would choose M frame for You!
The problem with 13A Firmware is that you feel there is resistance and you need more muscle strength to cycle.i noticed something simiar on 15A and 18A (46.7) firmwares from M600.
Have you noticed that on 15.8 13A from M500?
i may be wrong but i have a feeling on 13A 15.8 had no such effect - worth testing.
i am same size as you, I got a M frame and its perfect for me.Wiche Dengfu frame size should i choose?
S 15"
M 17"
L 19"
I'm 177 cm tall
Great I will also choose the same size
Thanks for sharing your experience with us.Just adding my experience:
I'm 178cm and L was too big
M was in the Goldilocks zone for me - just right! With a dropper at its lowest I can easily put both feet on the floor. I've got fairly short legs (30inch inside leg).
36T is pretty good for chainring for me, but I like spinning the cranks quite fast (around 95 cadence).
Yes, no problem.Great I will also choose the same size
I have another question, can you touch the ground with your feet when the saddle is at the lowest point?
27.5 in wheels with 2.8in tyres on both front and backThanks for sharing your experience with us.
What is your bike's wheel size?
