Kenevo SL What brake post mount do you need for Hope Floating Rotor.
MrMarzocchi
201
180
Wales
Hope got me to buy the wrong one...Kenevo SL...my rotor hits the SRAM caliper 🤦‍♂️ the rotor is 200mm
2WheelsNot4
893
692
Sometimes its very close and the best solution is to file a bit off the mount.
Whats the rotor size ?. Upping that can give you the clearance too.
MrMarzocchi
201
180
Wales
Sorry it's a 200mm rotor. I was looking at filing a bit back but didn't know if that'd mess it up. Is this normal practice or ?
Konanige
422
336
Mendips
That'll be because they are designed to run with Hope brakes not Sram. Buy the correct rotors then you won't have to BODGE anything.
Doomanic
🛠️Wrecker🛠️
8,492
9,978
Yeah. Weirdly, it doesn't clash on the Rail with Shimano brakes.
Doomanic
🛠️Wrecker🛠️
8,492
9,978
Yeah, the KSL has Sram brakes, the Rail has Shimano brakes. I transferred the wheels from the Rail to the KSL when I bought it.
Doomanic
🛠️Wrecker🛠️
8,492
9,978
Sram.
I really ought to chuck a Shimano caliper on there to see if it's the frame or the caliper at fault.
MrMarzocchi
201
180
Wales
Sram.
From a bit of research I heard SRAM are the least compatible with these discs but as long as it works.. did you change your mount or keep the SRAM one?
526K
