2009 kilometers since E8000 servicing on November 15, 2021
22 rides from km 17,423 to km 19,432 without any trouble or doubt.
View attachment 79808View attachment 79809
I think I have now a real opinion since my complete and successful
servicing of my e8000 DU,
and I would specify that I noticed this effect since the purchase on May 30, 2019
of my Husqvarna and before the first 17,423 kilometers of this third engine, the E8000.
When I opened the half dead engine on November 15, 2021,
I saw that there are two clutches and I attribute this effect that you show us with your video to the smallest of them:
it has a system as for winding a mechanical watch, when you turn the winder back and forth. I think this is "normal".
In the shifter of the derailleur you have a similar system with pawl and spring.
And I was very astonished that I didn't find any signs of wear or weakness
for all those little mechanical parts of this so small second clutch !!!
So small and so reliable and efficient!
The inner ring from the left bearing of the crank had an enormous and noisy clearance of 0.5 millimeters.
I guess, there was therefore abnormal and higher friction and pressure between the gears.
However, since servicing, electricity consumption
has not dropped at all, the range has not increased.
