Topham
To upgrade to fox 36’s or not?
Has anybody tried levo 2019 with 27,5+ wheels on? Does it even make sense to change the wheels to 27,5+ as all previous levos had?
If you can afford it, why not?! I would, the standard fork is a little harsh. I'm sure lyrik would be just as good an upgrade.To upgrade to fox 36’s or not?
In order to keep the same geometry you need also to increase the lenght of the fork to 160mm
Can you post picture of the bike, please, thank you.@Levo Lution
I did it with magic mary 2,6 and the bike is incredible!
It feel more like an non e-bikes and is lighter
Flip chip in hi position and lyrik 160mm in front, bb is at 340mm instead of 342mm as delivered (29 / flip chip in low position )
Thanks for the picture. 27,5 inch front and rear? On the picture it looks like front wheel is bigger.Here it is:
Magic mary 2.6 are a little bit bigger than butcher 2.6 but it’s better (and butcher 2,8 a too big)
27,5" bothThanks for the picture. 27,5 inch front and rear? On the picture it looks like front wheel is bigger.
Thanks for the inspiration ☺27,5" both
YesThanks for the inspiration ☺
Bike is size M?
You need to buy the new metric oneAnyone know if an Öhlins rear shock will fit in the new levo? Not that impressed with the fox that came with it
Don't be restricted by diameter. You could buy a shim for £6 and fit a brand X dropper for £98. Or plenty of other normal sized postsLoving my Base model but need to add a dropper. Should I go with the Manic 34.9 or is there a better option. Also, anyone want to sell your stock dropper?
You can get the Bikeyoke's Revive Max if you want the 34.9 mm BikeYoke dropper postsLoving my Base model but need to add a dropper. Should I go with the Manic 34.9 or is there a better option. Also, anyone want to sell your stock dropper?
I'm currently running 29x2.5 Maxxis Shorty Front & 29x2.4 DHR 2 rear. (There's a new 2.6 due soon'ish)If sticking with 29er wheels for UK winter riding is it worth switching tyres from the offset? If so which tyres are good please? I will want to run tubeless. Riding chalky, flinty paths, forests and occasional bike parks red/blue runs. Rider weight 90kg on speccy 2019 comp Carbon. Thanks in advance.
However get the shim and choose from plenty more droppers.
I've got myself OneUp Components OneUp Components dropper post and I'm very happy with 170 mm travel. Great price/performance ratio.
I installed the rockshox stelth reverb with the 1x remote. The 170 mm dropper will fit in a XL frame even all the way down. Happy with it so farLoving my Base model but need to add a dropper. Should I go with the Manic 34.9 or is there a better option. Also, anyone want to sell your stock dropper?
How is the handling compared to the 29er? I'm a shorter rider (5'3") and miss the ability to be more playful. I've been riding my 2019 Levo for a month now but I still struggle on tight switchbacks specially going downhill.@Levo Lution
Looks cool! What is it? A peice of shaped rubber?My LBS (bikescene) sent me this temp fix
View attachment 7417View attachment 7418View attachment 7419View attachment 7420
You think it would fit in the LG frame?
Nice!My LBS (bikescene) sent me this temp fix
Hi,Anyone know how tight that nut needs to be? Mine came loose just from removing the wheel
From Antony at bikesceneLooks cool! What is it? A peice of shaped rubber?
