Porto87133
Received today 2022 DHX2 and piggy bag is touching frame for 1mm. Now let's see if they can change it for shorterYes, I did. 65mm stroke is fine, the piggyback is shorter on 2021 and newer DHX2s.
That's disappointing. I just ordered a 2022 float X2 in 230x65...wonder if I'll have the same issue on my s4 frame?Received today 2022 DHX2 and piggy bag is touching frame for 1mm. Now let's see if they can change it for shorter
my bike is s4. Now I am sending back DHX2. Fox guy told me that it's not possible to change the reservoir for a shorter one.That's disappointing. I just ordered a 2022 float X2 in 230x65...wonder if I'll have the same issue on my s4 frame?
Is the dhx2 240x62.5 size or 65mm?Received today 2022 DHX2 and piggy bag is touching frame for 1mm. Now let's see if they can change it for shorter
230x65Is the dhx2 240x62.5 size or 65mm?
Bummer! Well I'll try the 2022 X3 when it arrives and report back. Worst case I'll send it in to fox to have it reduced to 62.5.Tried to fit my pre 2021 MY X2 factory 230x65 to my S4 frame. The air can is to big and was knocking on the lower linkage. The air can on the new X2 might be smaller in diameter, though.
Did it touch lower linkage when the shock is it's full lenght or when the stroke is it's minimum (when the shock is it's minimum lenght)Tried to fit my pre 2021 MY X2 factory 230x65 to my S4 frame. The air can is to big and was knocking on the lower linkage. The air can on the new X2 might be smaller in diameter, though.
Easy to do.
Touched when the shock was fully extended. Reducing stroke to 62.5 could indeed help since the air can will sit bit higher in the frame.
As @George_yt said, it doesn't shorten you shock total length. Same eye-to-eye lenghtTouched when the shock was fully extended. Reducing stroke to 62.5 could indeed help since the air can will sit bit higher in the frame.
Nice bike. My advice is to keep the front tyre Butcher T9. It's really good and well dampened.Ugly potato photo for now, but very happy with how it's starting to look so wanted to share :- ). I've been sick with bronchial inflammation for 5 weeks though, finally getting better, so zero riding, just staring at it.
KSL Comp. Added 2022 X2 Factory and Zeb Ultimate. Deity T-Mac pedals, and my old Enve DH bar/Renthal Duo cockpit. Tomorrow comes SQ-Lab Infinergy 60X saddle and will add my E13 wheelset, just need to decide on winter tyre combo. Probably keeping the T9 Butcher for back with CushCore Pro, and if that ends up being still bit weak, then swapping to dual-ply plus Cush but want to try the weight saving first.
T9 at the rear is too draggy.
Nice bike. I rode 3 times with the stock tyres and did not enjoyed a lot. Ordered my favorite combo, Magic Mary and Hans Dampf, cant wait to ride again tomorrowUgly potato photo for now, but very happy with how it's starting to look so wanted to share :- ). I've been sick with bronchial inflammation for 5 weeks though, finally getting better, so zero riding, just staring at it.
Had a few typos in my original post. It's a 230mm x 65 2022 X2.Sounds crazy to put a 241 shock in this high engineered bike......or other words, it simply makes absolut no sense, even when if really fits into. The result would be horrific and your hope that 6 possible Geosettings will fix it will not work.
And the shock on top of your Pic is not MJ 2023, it's 2021 or max 2022.
And the bottom shock is 2020 or older.
Cheers![]()
