...makes me realize that my noise dissapeared around the time I installed a kids-trailer hinge...... but it might be that they made an error and it really needed a 147 axle ? So maybe the answer is to place a 1mm spacer/washer over the axle so it clamps the rear triangle 1mm tighter together when it's tight ? ie, imagine the head is then 1mm thicker along the shaft, so the shaft is then effectively 1mm shorter....
Run a search through Amazon for the pads or Tektro TKD32. You will get a lot of results and prices look reasonable.Hello everyone! 1st post here!
What brake pads are you using on your EST900? Do you know alternatives to this A10GS from Decathlon? Here in Sweden they can only be ordered from Decathlon which is terribly slow for anything.
These seem to be getting some good user reviews. Not changed my pads yet, but might get these in for winter service.We are happy and safe with this
I'm running a 38T. Max pedal speed on the flat was around 22mph with it's original crank. Now I max out at about 28mph on the flat.Hey guys, anybody tried a 40t crank? I need longer gear ratios and just ordered one to try.
I hope you can stop this heavy bike with that 180 rotor and tektro brakesFor anyone who cares, I just fitted a pair of these ( 27.5x2.00 ):
( edit: can't post links for some reason, anyway, search for schwalbe big ben 27.5x2.00 )
Much better for my needs and if you're like me and need something between an mtb and a road bike, I am happy and I hope it saves you some research time ( If not, well, nevermind ).
They call that Gravel-bike, the latest trend, you are hip !...and if you're like me and need something between an mtb and a road bike,...
Hi there Azimuth
Your still running the old software my friend
It's the 7.4.1 software update that addresses a few issues
See if this link works
I purchase the Bikespeed RS Custom
Which allows me to fine tune the rate of assistance by percentage plus other handy things tucked away from prying if you know what I mean
Well this Xmas I will get round to putting everything I have accumulated over the past four month
Like all of you guys out there I'll give you updates on the progress
Malc
So it looks like your badass is a 1:1.5 pulse devider.
I suspect 1:2 would engage the alarm modus, so they limited the ratio.
With 37.5 or even 32 km/h I would be happy. Mine runs 45-50 km/h at the moment, nobody needs that.
You run 2.00 tyres, mounting 29" wheels could make you win some km/h"s
Road 28" tyres fit perfectly on mtb 29" wheels, look it up, bike manufacturers are crazy.
Hi there Azimuth
Malc
Speed is nothing without control. Hope those 2 pot Tektro TKD 32 are up to the task![]()
