My Chinese frame and motor build. The CHEEB, V1.0 - Build Thread
AlexRus
64
32
Russia
And yet another question, while trying to mount the lower crankcase, the only screws I have left are the four ones on the picture; but they don't fit. Where is my mistake ?
The two lower ones fit, the two upper ones do not - you need longer ones and with a different head.
I had the same problem
thaeber
878
766
Bruchsal, Germany
Not Your mistake - its Dengfu‘s mistake! You need 2 M5 Hex Screws with sunk head. The other 2 screws will work.
Roy68
57
36
UK Herts
Hei Guys
i have purchased the frame and motor from dengfu for a friend.Did you get a tracking number or it comes later?I have purchased 5 days ago
Don't think you'll get a tracking number for quite a while, my frame and motor took around 4 months but lead time may have improved now. Suggest you send an email to Melody to ask how long
savas
137
57
sofia
Yes i will talk with her.Actually i see right now the set is availabale on Tosa bikes.But at the day of purchase they didn' t have anything.Anyway i'will w8 gor a feedback
mdlampe
25
9
uk
Hi Rob or anyone,
I searched all thru this post and could not see where you had to cut the fork steer tube down to fit the e10. I take it you did? I will be building mine when the frame arrives and wondered if you had any other advice on the fork installation, other than the video.
Cheers,
Mike
markvanhaze77
37
15
GB
Hi Rob or anyone,
Cheers,
Mike
Well depends on your fork of course but yes, you will need to cut it. Plenty of videos on YT to follow on how thats done. I didnt even have the fancy tools so I just used a dremel and a metal file.
mdlampe
25
9
uk
Thanks Mark,
Ive watched a few videos but as this is my first build so I'm researching things five different ways. I ordered a guide to help my hacksaw cut a straight line, which it always refuses to do.
Cheers, Mike
patdam
806
551
france
Thanks Mark,
Cheers, Mike
use a plumber's pipe cutter
Roy68
57
36
UK Herts
^This
I have one of these for when my new forks finally arrive
Yeah pipe cutter always works for me, nice clean cut and perfectly straight. Just remember to take it nice and slowly
mdlampe
25
9
uk
mdlampe
25
9
uk
Feck that! Never painting a frame again ? A lot of work. Also I like the slab grey Zeb / purple contrast ?
Hi Rob,
On V1 Cheeb, now many cans of spray did that take you? I see they sell kits but wondered if it took you 2 or 3 kits, (one base, one colour, one clear per kit)? It's obvoiusly hard work and time consuming. I used to do cars.
Rob Rides EMTB
Administrator
Staff member
6,170
13,314
Surrey, UK
Hi Rob,
I think I bought 4 cans but had a can left
Kiwin
36
34
France
Hi All,
does anyone know where I can find spare derailleur hangers for the E10 ?
I would like to have some in case the one I have breaks.
I would also like to modify one a bit in order to move the derailleur a little toward the front. I feel that my derailleur does not allow the chain to work on enough teeth and it would be better tuned if it could be moved of 2-3 mm front.
Any idea ?
mdlampe
25
9
uk
Hi All,
Any idea ?
I have the same question, I have just emailed Melody at Dengfu, waiting a reply.
Dengfu
47
27
Question re:
What torque should this be?
Also, at the other side, should it look like this (threads showing) or is there a part missing?
Kiwin
36
34
France
I'd like to buy the spare parts on the schema. It seems bafang won"t sell the part in the blue circle separately from the chainring.
Do you know elsewhere I could buy such corresponding part ? (I don't even know how to name it) I would like to find a lighter one...
savas
137
57
sofia
Hi Team,
anyone knows where to get a bms which can do Can communication with the motor ?There was a link long time ago .I have received my 2nd frame ,this time only with battery box.Soon the motor will be delivered as well.
Sheff73
98
82
Hi Team,
Are you thinking you need a BMS with CAN communication for the motor to work when making / supplying your own battery? If so, that is not the case.
savas
137
57
sofia
Hi Sheff73,
yes in order to get the correct battery status i guess.But thinking about it you are correct it is going to be difficult to get the job done.The provided battery from Dengfu,does it use can communicationor Uart at all?
Waynemarlow
1,065
873
Bucks
Your voltage levels on the screen will show correctly without the CanBus BMS, its just the other stuff like how many more miles to go, number of charges, Coloumb counting for better management etc which on some screens will not be able to be shown.
Sheff73
98
82
Hi Sheff73,
All I can say from my experience / build (and others on here) is that to get the system to work (and show the voltage correctly on teh display), you just need to connect your battery directly to the XT60 connection on the motor, simple as that :)
Sunburntwily
95
52
I didn't realise you could display voltage. I only have percentage displayed. How do I get voltage displayed please?
525K
