Nukeproof Megawatt Owners Thread
St unlocker gives you instruction to downgrade takes 5 mins to works perfect
Here are my current settings. @Ripping g on profile one in eco mode you can select assi level 5. On my E-TUBE app I can only select level 3. Using st Unlocker I can select level 5.
Nice, could you do me a favour? And check to see if you have a white outline around that black bolt on both sides?
A lot of the early reviews talk of a gap between the battery cover and frame between the top/bottom mounting points i.e. the battery cover bows out slightly and isn't flush against the frame. It was quite an obvious gap for water ingress.
Apparently Nukeproof said this was a preproduction issue and would be addressed. Have you guys found this to be a problem?
Also, is this just plastic (battery cover) directly against metal (frame) or is there some kind of seal/gasket as well?
I'm very interested in the bike but would hate to worry about riding in the rain or washing the bike if it were that easy to allow water in.
There is a rubber seal around the plastic battery cover, it does sag a bit but nothing crazy and I’m yet to find water in the battery compartment even when I’ve cleaned it with a hose.
Damn. Bummed to hear that. I'm pretty put off by any design that loads the battery from the bottom (most, I know) and that seems pretty unacceptable.
I received mine today just finished setting it all up, I'll take it for a spin tomorrow. I would have gone for the elite but I really liked the green.
Could some one tell me where you'd find the serial number I want to register the bike?
the police cycle data base thing:
Mine went back to tredz got motor error 1030 after 52 miles couple of months for replacement motor couldn't be bothered to wait so got a refund picked up another kenevo from race co cycles this morning
Awww not bothering wi that if it goes missing you won’t ever see it again ??‍♂️
Never missed a beat so far I’ve got a levo as well carnt go wrong with the spec ??
Same, but after 52 yards, so added to a ripped seat,damaged stem and cracked screen, that went back to CRC too.
Mines awesome but I can’t ride at mo after coming off and smashing my T6 in my back. Bikes ok tho lol.
In fact I've had 2 megawatts first one rear shock fecked up and the battery came loose the second one motor fecked up, my nephew's megawatt is ok but complained of a knocking noise took cover of bike and the battery fell out the whole locking part at the top of battery came away from the frame 2 screws hold it to the frame 1 is missing and the other looks like it never was screwed into the frame at all
Ep8 motor is the weakest motor out of the Bosch and brose thou, but I do have a brand new E8035L battery never been used going up for sale still in box never got to use it?
which model/size was that? I just bought one of the ones from tredz which came back into stock - hope its not your return!!!
    668K
