Is the correct headset size for the E-160S?
EchoLima21
62
55
Surrey, Uk
Hi all, can anyone confirm for me if these are the correct headset bearings for the E-160 S?
FSA SA No.57E Orbit Tapered Headset Sealed Bearing 1.5E ZS 1-1/8"-1.5" OD 50mm/62mm
I can't find the precise information anywhere - the best I can do is:
"FSA No.57E Orbit ZS, 1 1/2" lower end and 1/18" upper sealed cartridge bearings"
from the Whtye site. The bit I'm concerned about is their mention of "ZS". Is that important/relevant?
Thanks in advance,
DB
Clubby
159
132
Tayside
Never used the seller but found these here. Look like the right ones to me.
KennyB
824
562
Taunton
I think this is the headset I had on my Whyte 905. Bearings were expensive to replace and sealing was poor so I binned the bottom (and later the top) set and fitted Hope mix and match ones for little more than bearings alone. Much better sealing and still going strong 3 years later.
EchoLima21
62
55
Surrey, Uk
I replaced the lower bearing on my 2020 Whyte E-150 with this a few months ago.
Didn’t have any info, just measured what came out and selected the same size bearing in stainless from Aire Velo Bearings online.
Perfect
ACB518K-SS STAINLESS £16.67
edit. Just looked it up, it’s £20 now
Out of stock, but thanks ?
EchoLima21
62
55
Surrey, Uk
Bought and fitted - thanks v much ?
