ENGINE AND BATTERY
The Patron eRIDE is equipped with the latest electric technology from Bosch. Do you want more autonomy? The Patron poses a new standard with the
new 750 Wh battery and its 20% higher additional capacity.
With a maximum torque of 85 Nm and 340% more power, the Bosch Performance CX motor can offer assistance ranging from light to very powerful, and thanks to the Bluetooth connection, you can adjust and customize its modes on the fly . The battery can be easily removed, thanks to the sliding door.
DISPLAY ON THE HANDLEBAR
Connectivity, versatility and visibility are keywords for the
Kiox 300 LED Remote. The
Kiox is a 2 "color screen integrated into the stem.
It displays all information including speed, GPS, cadence and offers a Bluetooth connection to the eBike Flow app. It can be removed and monitored by the LED remote control or by a telephone. The new LED remote control displays the current charge status and allows you to select the various modes.
The all-new Patron eRIDE 920 has been designed with a system optimized for trail rides that last a day. Supreme integration and carefully chosen geometry
paired with a new Bosch drive unit offer more than just one great bike.
Rather, what you get is a sublime experience up and down the mountain over and over again. Patron eRIDE: dominate the trails.
Main features: Patron eRIDE Alloy Frame; RockShox Domain 160mm Fork; FOX Float EVOL eRIDE, 160mm, TwinLoc; Shimano XT-Deore 12 Speed; Bosch CX, 750Wh PowerTube; Shimano 4 Piston Disc Brakes; Maxxis Foldable Tires; Syncros Dropper Post and Parts.
SHOCK ABSORBER INTEGRATION
The Patron arrives with a new design and revolutionary. The rear suspension is fully integrated into the frame and offers 160mm of travel. More than a simple design element, the integration of the shock absorber offers space for other elements such as the engine, the battery and a bottle cage. From easy access, the shock is equipped with our TwinLoc technology to lock the suspension directly from the handlebar to make pedaling efficiency optimal.
