ST Ride App - Tracker/dash/logger for STEPS motors
The new version for Android is available:
+ Assist mode usage in % (for each mode), also displayed on speedo as color arcs
= new version of Climb/descent calculation
= fixed font sizing when a phone has non-default font size
= extended session description for exporting
The new version for Android was released:
1. It's possible to resume recording sessions after loosing the connection
2. Auto reconnect feature for external sensors
3. Settings for smoothing Altitude, Assist Level, Acceleration
Hi there,
Just wanted to just double check this, I have a SC-E8000 this will not connect to ST Ride (although did it in the beta? is there a tech issue?) you need a SC-E7000 or EW-EN100 and you cant run a SC-E8000 and a EW-EN100 at the same time and there is no colour option for the SC-E7000.
If this is the case, gutted but hope the SC-E8000 and EW-EN100 are a quick swap as for longer rides normally attach phone for GPS.
Will the SC-EM800 work?
Loving the app btw
It's Shimano fault. Even their ETube Ride does not support SC-E8000
It 100% works with EP8 motor. But I don't know, if it will work with old motors
I now did some ride with your app. And I got one wish do add as information. My usage of preprocessing the data are aiming at getting the most out of the battery. So, would it be possible to plot (and perhabs have some stats) battery usage against altitude gain? Perhabs with color marked driving modes.
Appreciate your work,
Kind greets Bennet
You can see it at Statistics -> Charts
Kind greets Bennet
Just a quick update, there is something that works with the SC-E8000, just hooked up my Garmin Fenix5 to my old bike and it gives me D12 options one of which is Di2 battery which actually shows me the main battery %. I think there are 3 types of SC-E8000, one that does no ANT one that does Di2 and one that does everthing. Bikster sell three different versions but there appears to be no part number difference. sc-e8000 | bikester.co.uk I bought the £107 one as a replacement
The new version for iOS is available:
+ Landscape layout supported
+ Pause in the session recordings
+ Changing Dash/Map/List using Left/Right swipes
+ Multiple watch schemes
I can't upload to Strava. Strava is configured and in Settings is says connected. But I only get an error message "Can't connect to Strava"
Did Strava changed the api or something!?
Android or iOS?
Sorry. Xiaomi Android 11, ST Ride 1.7.48
I've checked on 2 phones with Android 10 & 11 system. All works fine. Try to re-grant access to Strava at App's settings.
p.s. PM for more details: does your phone has Strava installed? how did you grant access to STRide (via App or browser)?
I have Strava installed, can't remember if I granted access through the app or browser.
But re-granting access solved it. Used both app and browser to grant access this time.
Thanks a lot.
Apple watch support in the upcoming new version for iOS/WatchOS:
1. Heart rate from the watch
2. Connect/Disconnect, Start/Stop recording via Watch
3. Dash (there will be more)
Hi Vadll, the Apple Watch option is great!
Will you leverage the Watch OS 7 support to always on display in the next update?
iPhone is required, because iPhone provides Bluetooth connection with a bike. Watches are just for displaying data
Used this app (iPhone and Apple Watch) for first time this week on my new Orbea Rise with the LED display (no screen).
Brilliant! And perfect for giving me that important battery percentage. Thank you! Love the fact it’s on my watch.
But, how do I upload direct to Strava? I tried the ‘Strava’ export, there’s a spinning circle, but no upload.
It’s no biggie, as I can export the GPX (think I read it records heart rate in the GPX as well?), just would save a couple of steps.
But, for me without a display - brilliant! And I love all the stats to look at afterwards.
does it detect when you ‘pedal through’ the 25kph assistance limit?
Thank you!
You have to grant access to Strava at App's settings first.
Thank you - that did it! (Thought I’d done that already, but maybe each time on iOS 15.1?)
Still brilliant, but I think the calories used might be a smidgen optimistic. Thinks I did 1900 cals in 19mi. Lol
But, thank you, a really useful app!
It's strange. Cals works fine for me - it should be around 106 ccal in 19min (for 80kg and average HR 100)
Please check your weight at App's settings, make a session recording, export it into STRide format and send it to me.
    670K
