My Dengfu E10 with Bafang M600
Putting it through its Pacers really enjoyable 20 miles done only about 600 feet of climbing lots of mud level 1 to 3 mostly some in Hi but not a lot 65% battery left
Hi I used RockShox yari 180mm RockShox rc3 216×63 Offset bushing front and rear for shock 27.5 dt swiss 370 wheels madura 05 brakes 200mm front and rear and matt black spray from Halfords 150mm dropper seatpost 31.6 and the only thing I brought brand new was the seatpost most of it off Facebook marketplace or eBay
Can You please tell me the weight of Your bike? Thanks!
Ohhh shit...I would recommend to ask Melody for the correct replacement item or spare part spec. It‘s hard to judge if this is a standard derailleur hanger!
Drives like a dream, had flattened the steering angle by 1.5 degrees and with the power of the 600er, things really get going! Here are a few more photos of the battery:
I connected it with PowerPole to the Motor
Hi Karl.
I'm building my own battery for the E10 - Did you come up with some clever way of mounting your battery in the frame using the cable clamp points? or is it just wedged in some how? I was thinking of some sort of mounting plate with tie wraps or velcro straps.
Cheers.
Hi Karl.
Cheers.
Simply put industrial velcro hook and loop on the battery base and cover. The battery cover is more than substantial enough to take the loading, the hook and loop acts as a vibration damper, you get to lower the battery down lower in the frame as you do not have the connector housing and you can simply unclip the cover to charge. Works really well as I have a smaller battery for the 1 hour blasts and an 800 W larger version for the 4 hour rides.
Thanks for the info.
My frame has the newer 'catch opening cover' not the screw attached of old, so not sure I'm happy mounting 3kgs to it...
Hi. Would like to ask if aside from the stock lcd display the m600 comes with, is there any other display that can work with m600? plug and play. Thanks
I have this controller on another Ebike & its excellent but alas here the Bafang M600 uses a CAN (bus) system. You need a CAN compatible display, can find on Luna Cycles website or Alibaba - see link
thanks. ill try at alibaba
[QUOTE = "Funfunfun, publicación: 328627, miembro: 7329"]
Hola, ¿funcionaría también una pantalla alibaba CAN M600 860c? Solo lea, puede estar limitado a 25 mph -> 69.8 £ 28% DE DESCUENTO | Ebike Display Bafang 860C para motor medio M300 M400 M600 M800 Pantalla de bicicleta eléctrica con conector triangular macho o hembra | Accesorios para bicicletas eléctricas | - AliExpress
[/CITA]
Tengo esta pantalla (y otras), tengo bluetooth y es compatible con M600.
The limit of M600 is 45 km/h
[/CITA]
ok, so this should also work. CAN m600 860c --> Bafang eBike Display LCD 860C 160 M620 M400 M200 Bicycle Controller Speedometer | eBay thanks
Cable verde del motor
Necesitará un extensor para el cable rojo.
[URL unfurl = "true"] 5.22£ 29% de DESCUENTO|JULET Cable impermeable BAFANG Cable de extensión luz del Motor Ebrake Acelerador de 1T4 1T5 2 3 4 5 Pin conversión Ebike Cable|Accesorios de bicicleta eléctrica| - AliExpress [/ URL]
El modelo es de 5 pines macho hembra
hice una caja para la pantalla con la impresora 3 D
Puedo enviarte el archivo STL
Thanks...and how did you attach the 760c unit to your stem of the bike? Cheers
[/QUOTE]Cinta de dos lados. Esto es lo mejor:
[MEDIA = amazon] id = B008OEFWLQ; tld = es [/ MEDIA] = 7786646270548473941 & hvtargid = kwd-646351791000 & hydadcr = 10914_1790924 & keywords = ceys + montack & qid = 1629789845 & sbo = RZvFAn% 2FH50% 2 % 3D & sr = 8-1
Si quieres el archivo de la caja debes cambiar ".pdf" por ".stl"
