My Dengfu E10 with Bafang M600
KaroKönig
A BOM (Bill Of Materials) would help. From the photos I think I recognize :
- CrankBrothers Twin Pair Spoke IODINE 2 AM wheels, size ?
- Sram GX Eagle grip shifter (11 or 12 speed ?) which also requires a matching GX derailleur. Cassette also looks like Sram.
- Magura MT5 Estop brakes & Magura Estop discs 203 mm ?
- Front: RockShox ZEB, Ultimate ? 160 mm ?
- Rear: RockShox Super Deluxe Ultimate ?
- dropper ?
- dropper ?
You have a good eye ?
Iodine 3 in 29“ and 2.60 tires
ZEB Ultimate 170mm
Superdeluxe coil rear shock
Magura E-Stop with 223mm front/203mm rear disc
Fox transfer dropper 150mm
GX 11speed gripshift and cassette
Nice bike!
Which adapter did you use to fit the magura e-stop caliper with the 220 disc to the Zeb fork?
I am just here for that scale - quite the bit of kit - for weighing fish isn't it?
FalconSL is definitely impressive, another awesome E10er :love:(y)
How does it ride?
Drives like a dream, had flattened the steering angle by 1.5 degrees and with the power of the 600er, things really get going! Here are a few more photos of the battery:
I connected it with PowerPole to the Motor
wow looks do able, I might try it if I can find these parts in the USA. Would you mind listing the parts? Much appreciate it!
56x Sanyo/Panasonic NCR18650GA 3,6V - 3,7V 3500mAh *Lötfahne U | akkuteile.de
1x 14S 45A 50.4V Li-ion Lithium Batterie Cell Protection BMS PCB Board mit Balance | eBay
1x Anderson PowerPole® DC Verlängerungskabel Cu/Kupfer
you also need a soldering iron, shrink tubing and a hot glue gun. And be careful with the lithium cells not to cause a short circuit ?
Very nice colour !
What is the size of your Superdeluxe coil rear shock ?
    Join 43,203
