Puschtrale
Finally ?. Just waiting for the bottom bracket tool and then I can testride this bike ✌?
Thank you
looks good to me. is it in all the way?
What size frame you have? I'm wondering if a coil will fit on a small frame?
Looks good to me ?Hi guys. Is this correct regarding connections on the bafang m500? See picture. Thank you. View attachment 62158
Im not sure for the throttle.Hi guys. Is this correct regarding connections on the bafang m500? See picture. Thank you. View attachment 62158
looks like a good build, hope your half as pleased as I am, I decided not to paint mine, I've left it in raw carbon, for now....
My throttle plugs into the yellow plug off the display lead, not on the motor.Hi guys. Is this correct regarding connections on the bafang m500? See picture. Thank you. View attachment 62158
Building the E10 bike with befang e600 motor. I am missing the engine mounting bolts. Any idea what they are so I can buy in Australia or somewhere quick. cheers
Thanks alot. Very helpful.The bolts are quite specialised unfortunately....
They are M8 cap head bolts, with length of approx. 65mm (from under the head to the end of the bolt) and thread length of 10mm. You need 3 in total. Also a plain washer and Nyloc nut for each bolt. The head width is also quite thin at 2,5mm.
In the video you mentioned getting the bike wet and it stopped working!ACF50 - just spray onto electrics and wipe off with a rag. I used to use the stuff on all my motorbikes in the UK winters and it lasted forever. Its quite a thick viscosity so sticks well.
Hello Dean i have the same issue ,the print (controller) has water damage so i think the Internal protection is not the best i think ...send a mail for warranty grtz .In the video you mentioned getting the bike wet and it stopped working!
What were the issues? As after a ride I got carried away with the hose pipe and whe I turned the bike back on the display read 0% even though the battery was 80% before I washed it.
This has also happened about 7 miles into a ride previously. (But could have maybe got water in the electrics the previous time I washed it ??)
When powering up a distinct ticking noise can be heard from the battery.
Both times after leaving the bike a day or so I have put the battery back in and bike was ok again.
Also on the last occasion 1.5 days later the bike started driving on its own while I was re setting the trip counter and brought up a hand throttle error code.
Then I lubed the chain turning the crank and when I stopped after a few seconds the motor started driving on it own.
On the right side oxidation on the print !(controller)Hello Dean i have the same issue ,the print (controller) has water damage so i think the Internal protection is not the best i think ...send a mail for warranty grtz .
Hi Rob
In your YouTube video you mentioned getting the bike wet and it stopped working!
What were the issues? As after a ride I got carried away with the hose pipe and when I turned the bike back on the display read 0% even though the battery was 80% before I washed it.
is this on the side of the motor? as I looked inside and mine it was dry and no sign of water ingress.On the right side oxidation on the print !(controller)
yes inside the motor (controller print),also ticking noise from the battery ,should be the prorection off the baatery that you hear i suppose ..i have 2 battery and different display ...all the same ...print is gone and corroded be the water ...is this on the side of the motor? as I looked inside and mine it was dry and no sign of water ingress.
I think I got water in the mode/power switch or the display.
do you get the ticking noise from your battery ?
Ok thanks will check again tomorrowyes inside the motor (controller print),also ticking noise from the battery ,should be the prorection off the baatery that you here i suppose ..i have 2 battery and different display ...all the same ...print is gone and corroded be the water ...
Also my bike still works once water has evaporated is you bike working now ?Ok thanks will check again tomorrow
No it does not ! just done 200km from new ...4 rides from new )-:Also my bike still works once water has evaporated is you bike working now ?
I hope they sort it out with new parts for you under warrant. not good.No it does not ! just done 200km from new ...4 rides from new )-:
Yes al the same as you discribed ... )-:I hope they sort it out with new parts for you under warrant. not good.
Did you also keep getting different random battery % readings on your display?
