Other 2022 Kenevo SL Rumours ..
Status
Not open for further replies.
S sizing. Adjustable geometry. Very light even with Fox 38 options. Otherwise as SL motor and battery.
Man $11k for that spec. I was also hoping for a steeet sta. But overall looks killer
Honestly I'll be a bit disappointed if they didn't bump power up a little. It's not going to be the same long distance bike the Levo SL needed to be, so range shouldn't be assumed as a big selling point. These will definitely be heavier when it's all said and done and that's going to make them feel like slugs compared. Don't get me wrong, I'm still getting one tomorrow I just want more power!
Me too - I was hoping they would take a que from Orbea with the 60nm motor which sounds spot on.
so what they released is the top of the line, by previous expierience when will they release a comp you think?
also will there be a alu comp or will it stay carbon only? pricing is the same as levo SL here in belgium so hope this trend stays.
Can handle levo sl alu comp price maybe even comp carbon but more is too much for my wallet/use :s
S-Works £12,500
Expert £8,750
Frameset £6,500
S works Kenevo SL Technical Specifications
COCKPIT
StemDeity Copperhead, 35.0mm
HandlebarsRoval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 800mm, 35.0mm
GripsDeity, Knuckleduster, Black
SaddleBridge, 155/143mm, Hollow Ti-rails
SeatPostRockShox Reverb AXS, 30.9mm, S: 125, M:150, L/XL: 170mm
BRAKES
Front BrakeSRAM Code RSC, 4-piston caliper, hydraulic disc, 220mm
Rear BrakeSRAM Code RSC, 4-piston caliper, hydraulic disc, 200mm
DRIVETRAIN
Rear DerailleurSRAM XX1 Eagle AXS
CassetteSRAM XG-1299 Eagle, 10-52t
ChainSRAM XX1, 12 speed
Shift LeversSRAM Eagle AXS Rocker Paddle
CranksetPraxis Carbon M30, custom offset
ChainringsSRAM X-Sync Eagle, 94 BCD, 32t, alloy
WHEELS
Front WheelTraverse SL 29
Rear WheelTraverse SL 29
Front TireButcher Grid Trail T9 29x2.6"
Inner TubesStandard, Presta valve
Rear TireEliminator Grid Trail T7 29x2.6"
E-BIKE
MotorSpecialized SL 1.1, custom lightweight motor
BatterySpecialized SL1-320, fully integrated, 320Wh
ChargerCustom charger, 48V System w/ SL system charger plug
UI/RemoteSpecialized MasterMind TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
Wiring HarnessCustom Specialized wiring harness
FRAMESET
FrameFACT 11m full carbon, 29", full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 170mm rear travel, geo adjust head tube, geo adjust horst pivot
ForkFOX FLOAT 38 Factory 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 170mm travel, Kashima
Seat BinderAlloy, 38.6mm
SUSPENSION
Rear ShockFOX FLOAT X2 Factory, LSC, LSR, 2-position lever, 62.5x230mm, Kashima
* Specifications are subject to change without notice
Kenevo SL Expert Technical Specifications
COCKPIT
StemAlloy Trail Stem, 35mm bar bore
HandlebarsSpecialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 800mm, 35mm clamp
SaddleBridge Comp, Hollow Cr-mo rails, 155/143mm
SeatPostX-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9mm, S2: 125mm, S3/S4: 150mm, S5: 170mm
BRAKES
Front BrakeSRAM Code RS, 4-piston caliper, hydraulic disc, 220mm
Rear BrakeSRAM Code RS, 4-piston caliper, hydraulic disc, 200mm
DRIVETRAIN
Rear DerailleurSram X01 Eagle, 12-speed
Shift LeversSRAM X01 Eagle, trigger, 12-speed
CassetteSRAM XG-1295 Eagle, 10-52t
ChainSRAM GX Eagle, 12-speed
CranksetPraxis, forged M30, custom offset
WHEELS
Front TireButcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3"
Front WheelTraverse 29
Rear WheelTraverse 29
RimsRoval Traverse 29 Alloy, 30mm inner width, hand-built, 2Bliss Ready
Front HubRoval, sealed cartridge bearings, 15x110mm spacing, 28h
Rear HubRoval DT Swiss 370, Ratchet LN, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
SpokesDT Swiss Competition Race
Rear TireEliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 29x2.6"
FRAMESET
ForkFOX FLOAT 38 Performance Elite 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 170mm travel
E-BIKE
SUSPENSION
Rear ShockFOX FLOAT X Performance, LSR, 2-position lever, 62.5x230mm
Sworks Kenevo Frameset Technical Specifications
E-BIKE
FRAMESET
SUSPENSION
DRIVETRAIN
Enduro suspension kinematic and Mahle motor, just what I want. Weight about 20 kg
I am happy with my order
Wow.. 150mm seatpost in this day and age on the S4 and Fox X2 performance on the expert. At least the 38 is performance elite
Got the 2023 Kenevo full fat spec as well but got a feeling its embargoed ?‍♂️
Lets just say if you know how to use Google and cached search results you may be able to see a copy of the Specialized Kenevo 2023 webpage before their marketing team pulled it ?
Status
    668K
