Hello all, I'm a newbie. This thread has been great, very informative.
So, after stalking CRC for a while a medium VR magically appeared in stock a few days ago, and I bought it. Now apart from the fact that it seems a bit suspicious that a lone bike at full price has turned up months after they all sold out (was it a return... a refurb... ex demo... hiding in the basement... ??) I have also been having size anxiety.
I'm 5' 6" and a half (169cm) and very borderline medium. My current bikes are both medium frames and fit well with aftermarket shorter stems, but I can only fit short droppers on both - 125mm on my hardtail (Saracen Mantra) and 100mm on the Boardman FS. Both posts are pretty much fully inserted. Obviously I'm not going to fit on a 150mm dropper so these are my options: 1. fit a shorter dropper 2. shim the 150 (I don't even know how to do that, but I can learn...) 3. cancel the order and wait for the 2019 bikes - hopefully November - and get a small.
Smoky Jo's post comparing the fit of the sizes was really helpful, Gary's evangelism (can I say that? ... thanks Gary) about benefits of smaller sizes also helps sway my thinking, and I'm leaning towards 3. cancel and get a small.
Any thoughts?
Cheers, Dan
I don't buy in to the small sizing evangelism
Mech hanger turned up today, fitted the new one, threadlocked and the fit is fine, no movement or excessive wear to the seat stay from it coming loose... Phew! have kept the hanger part as a spare.
Also replaced the front hub bearings as there was play. 1000miles? not great, not all that unusual though (I'd actually blame the newer maxle design for premature wear as it's tricky to get the clamping force just right with the lever closed parallel to the fork leg without a bit of faffing)
When refitting the end caps I didn't have a socket a suitable size for the outer rings that press in last so ended up pressing the non disc side on ein by hand until it was flush (not actually pressed in far enough and ended up resorting to freezing the disc side one to get it into the recess. Not ideal at all. Fucking shitty design. What does anyone else use? Socket? proper tool? or did you find a tube with the correct ID/OD somewhere? Please share as I really don't want to buy a DT tool.
Ah... Bodged locators I did have. Mine were far more ingenius i reckon though...Set of grips with appropriately bodged locator?
That's what I was looking for but didn't have any that would fit. What size socket did you end up using?fitted the torque caps on my H1700 front wheel and happened to have a socket that perfectly sat over the cap but small enough to not catch the hub shell.
I ended up freezing the rings, dropping the non disc one in and just pressing it in by hand and finishing off with a block of wood and hammer, The disc side needs to be located far deeper so I dropped the even more frozenring in locating it by pressing it in with wooden 3 barbeque skewers from the cutlery drawer, then waiting for them to thaw. not ideal but they seem secure(ish) but I'm 99% sure neither is fully located,
Might make my search easier.
Actually, thinking about it, 27mm OD PVC pipe would do the job perfectly I reckon. Pity there's not a plumbing supplier close by
googling 3/4" ID PVC pipe is 26.7mm OD so that sounds perfect
Brilliant. Cheers!
Anyone think this frame looks familiar?
Kelly's E-Bike Theos AM Shimano STEPS E8000 / Deore XT 11 Speed | eBay
Thanks mate. I had a 22mm here that was too thick but no 21mm. I'll try and raid my motorbiker mate's sockets next time I'm round there to make sure it's seated properly.View attachment 5943
21mm socket should do it but I borrowed a 3/8 drive socket off a mate that had a thinner wall and fitted perfect.
KTM_E-Bike-Katalog-2019_Preview05.pdfThe KTM (Astro) frame I saw spyshots from interbike of looks promising. KTM did a great 27'5 Ironhorse Sunday (almost) rip off a few years ago with sorted (decently low/slack geo) that was ridden to pretty decent success in US National DH races. Hopeful they got their numbers and kinematics rigt on their Ebike
