Finished with the upgrades and installation of Ridewrap. Upgrades tires, bars, stem, dropper, saddle & grips. 1st ride tomorrow!
TECHNICAL SPECIFICATIONS
2021 YT Decoy Elite
FRAMESET
Virtual 4-Link rear suspension
Mixed ("Mullet") wheels: 29" front, 27.5" rear
Internal cable routing.
CRANKSET
SHIMANO XT
FCM 8050 | 165 mm
WHEELSET
CRANKBROTHERS SYNTHESIS E11
Front 29“ x 31.5 mm 110 x 15 mm
Rear 27,5‘‘ x 35.5 mm 148 x 12 mm
HUBS
Industry Nine 1/1, 110x15mm Boost front, 148x12mm Boost rear with MICRO SPLINE driver
FORK
FOX 38 FLOAT FACTORY E-BIKE
29“ | 170 mm | 15QRx110 | 51 mm Rake | Grip2
REAR DERAILLEUR
SHIMANO XT
Shadow Plus | 12 - Speed
Shifter
SHIMANO XT 12 - Speed
SHOCK
FOX FLOAT X2 FACTORY
230 x 65mm | w/2-Pos Lever
MOTOR
SHIMANO E8000 70 NM 250 W
DISPLAY
SHIMANO E7000 Monochrome
BATTERY
SMP YT CUSTOM Removable 540 Wh 36 V
STEM
Deity Copperhead 31.8MM x 50mm
CASSETTE
SHIMANO XT 10 - 51T | 12 - Speed
CHAIN
Shimano XT
CHAINGUIDE
E13 TRS PLUS E8000 2 Bolt 34-38T Compact Slider
HEADSET
ACROS AZX-260 BLOCK LOCK High Cap
BRAKES
SRAM CODE RSC
Rotors CENTERLINE 220mm/220mm
CHAINRING
SHIMANO SMCRE80 | 36 T
WEIGHT
50.48 LB
SEATPOST
Rockshox Reverb AXS
Ø 31.6 mm 150 mm travel
HANDLEBAR
SQ Lab Carbon, 4-degree upsweep, 12 degrees backsweep, 45mm rise, 780mm, 31.8mm diameter
SADDLE
Ergon SM Enduro Comp Stealth
GRIPS
ODI ELITE Lock-On
FRAME SIZE
Large
COLOR
DARK SLATE
SWITCH
SHIMANO E7000
On-Bar | SWE7000L
WHEELSET
27.5‘‘ x 35.5 mm 148 x 12 mm
FRONT TIRE
Michelin E-Wild
29“ x 2.6
REAR TIRE
Michelin E-Wild
27.5“ x 2.6
