It's the new standard. I've seen quite a few busted Marzochi coils but only one rockshox coil snapped on a German website.
I guess specialized have decided air is more suitable, either due to a stronger shaft or more likely to be set up correctly for the riders weight.
I wouldn't want an air shock either. I've never had one last more than 12 months without having the damping fail.
I partly blame specialized for not providing a suitable spring chart for riders weight like they did for the 19 kenevo.
I would hazard a guess a spring that bottomed hard here!
Thanks for you reply,
I will test the air shok an see how it gos
I thought the same but a friend has it on his and also spoke to tftuned who confirmed it’s ok , it feels the same as stock but stiffens the more it compresses ( obviously ?) . Slowed the rebound down a click or 2 and it’s sweet !
It's dog tight on the rockshox ?
Kenevo S5 owners
Hi
I have been looking into E MTBs for a while now and have decided to go for a Kenevo. I think it would suit my riding style best as I love DH and jumps etc.
However the S sizing system has me a bit confused. I am 6'3" so on paper I guess I should be going for the S5. However I am thinking as soon as the trail turns from flat out openness it anything twisty and technical the the S5 will just be too long and I the S4 would be a better bet.
This will be a general purpose bike and get used for everything from a DH shuttle to riding around the local (flat) trails in the woods.
Any input would be much appreciated.
Thanks Dave
Kenevo S5 owners
Hi
I'm same height and ride a S5. Reach wise I could happily ride either S4 or S5. But pedaling position (top tube length) is not that long on the Kenevo, and S4 would be quite short and cramped. Long reach and chainstays make a nice, central riding position. It's superb climber. I really like S5. I really can't comment on the twisty and technical, other than it just works for me. The boring answer is, you need to try them both.
MRP progressive coil fitted today.
At about 93kg the stock 550 gave me the required 30% sag but did suffer the occasional harsh bottom out.
With this just tightened enough to stop rattle its just over 30% sag, so pretty much perfect.
Hopefully be dry enough at the weekend to test it.
I ride an S4 and I'm just under 6'2, and I find the seat needs to be moved all the way aft to get enough room for myself, especially on descents. I have a feeling you'd be OK on an S4, but might be better off on an S5.
Kenevo S5 owners
Hi
Thanks Dave
Good day all!
Anyone installed a Rockshox Reverb Stealth on the 2nd gen Kenevo? I am wondering if the cable loop within the frame will cause any problems to installation/bleeding etc. The wireless option is crazy expensive...
Brgds/Nikolaos Tsivis
Just under 6'2" as well. Was originally planning on an S4 but my LBS had both an S4 and S5 made up so I took them both out for a spin and against my expectations preferred the feel of the S5. As others have mentioned, despite the long reach figures, the cockpit is smaller than you'd expect when seated.
Has anybody swapped the Boxxer fork to a Rockshox Zeb and can provide their thoughts on the performance difference?
Currently toying with the idea.The limited steering lock of the Boxxers annoys me from time to time on the switchbacks.
After months of decision making i finally decided to order myself a kenevo comp today in dove grey from my LBS, not going to be in stock till 19th feb so long wait ahead for me. Cant wait to get it though my first ebike and also a big change from my current trail bike, looking forward to the long travel and growing in to the bike as my riding progresses.
My 2020 Kenevo mid transformation. Size S4 with 200mm front and rear.
Going to run a XO1 DH drive train.
Waiting for the rear wheel to be built kind hub with crank brothers synthesis carbon DH rim.
Waiting on axs dropper.
I just wanted to get it rolling to check for clearance, HA and BB Heights.
That’s one nice looking bike dude
Danrodcr , I ride both bikes , in a previous post you will see the mods I did to my kenevo , I did put 29” wheels on it , so it rolls very much like the Levo , it does have a longer wheelbase so if you’re not to good a tech rider you will feel the difference on tight tech trails , but in general I prefer riding the kenevo as it just soaks up anything and rides well on all terrain . The stock kenevo is very low and with a very linear rear end and a coil spring , it peddle strikes everywhere which the Levo doesn’t do much , the Fox 38 and X2 air shock and 29” wheels transformed my Kenevo into a bike Specialized should have produced imho
How do you get a 29 rear wheel to fit mate ?
Nice bike.
what sice is you shock from Cane Greek
Nice bike.
It was originally a 9.5 x 3 but I made a few custom bits for it but cutting the piston shaft by 6mm and re-threading it. To bring it down to 233mm eye to eye. Then using an offset bushings and the flip chip in low got it pretty close to stock geo.
Sweet.
i plan on switching my standard shock to a fox but would really like 200mm
If you get a 230x65 gives you around 190mm of travel. Thats enough for the kenevo. At 200mm it was just squishy. Didn't add any extra control or stability.
Plush its far less messing about.
Thanks i will go for the fox dhx2 230x65
Does anybody know of anywhere to find a new Rock Shox or Fox Kenevo shock for sale in the states? Air or coil. Bike shop can't find anything and I can't find anything online but maybe I'm not searching right.
Motor expired on today’s ride , luckily it started to slip and misfire towards the end of ride but eventually died at the bottom of peaslake village so needed a toe up to hurtwood carpark . It didn’t scream it just lost all power to cranks , so probably the sprag bearing I think ! I got 14 months out of it so can’t grumble !
My motor died on the weekend. Started losing power when the motor got warm then started making a whir...whir...whir with very little assistance. The shop says it will take a week till I get it back. I think at least 2 weeks.
Hi folks.
I’ve a 2020 Kenevo Comp w/ a Marzocchi CR Bomber damper. I’d like to swap to a Fox DPX2 230x62.5/65.
Do you have experiences, which bushing size I need to order (Fox OEM or aftermarket)?
Thanks. Tom
Hi folks.
I am looking to buy the Kenevo Comp but not sure on the size I would need, I’m 5’ 6” what would you guys recommend.
Cheers
Hi folks.
Cheers
I’m 5.10 on a medium so you could be a small or if you prefer a big bikes go medium !
I’m 5 10 on a S3 ....its bigger than my large YT Capra C .....fits me like a glove
I am also 5'10 on an S3 and it feels perfect, as a matter of fact this is to me, the best fitting bike I have ever owned or ridden.
    Join 43,227
