YT Decoy with Fox 40
TheMattieB
13
12
LA
Did a little photoshop... beastly
Dirtnvert
1,353
1,600
BC Canada
Oh ya, do it. Coil on the rear and 49 set at 190. At 180 a triple is the same axle to crown as a 170 single crown
snaken612
Essen NRW
Hi !
I have the Pro Race (2019) and a FOX 40.
I would like to install the fork and I can share it with you.
BUT can someone tell me how I can reduce the travel of the Fox 40 from 2021 to 190mm?
Now it's 203mm.
I searched everything desperately but found nothing.
MUCH THANKS !
snaken612
Essen NRW
yeah i do !
but i must wait for the rim (because its 20x110 and now i have 15x110) and i want it on 190mm before i buildt it in.
Sorry for my english :D !!
Camstyn
121
142
Kamloops BC
If I’m doing my math right, a Fox 40 (at full 203mm) at 20% sag with a 27.5 wheel will actually result in a lower front end than your 29er 36 set at 160. That being said you’d actually be better off with the 49 fork with a 27.5 wheel which would result in a front end height falling somewhere in between the 160mm stock front end from 2019 and the 170mm from 2020.
TransAmMan
154
142
Canada
If you need to lower the front more .. remember a 1 degree angleset headset will lower it the same amount reducing travel10 mm.
So if you can get your fox 40 to 180 mm and run a 1 degree angleset (64 HA) you will have the same front end height as stock.
Looks incredible .. I may follow suit on my 2021 decoy
