Eddy Current
- Thread starter
- #121
You can add media here
Done
111 notifications plus 1 message. I couldn’t live with that on my screen.You can add media here
CamelbakWTF?
Why are you carrying over a stone ofshitestuff on your back to ride an Ebike in the woods?
Addressed to Jimmy'll fix it?£10 in an envelope
111 notifications
Sorry - like Lycra - Speedo’s especially small ones, budgie smugglers, mankini’s and merkins have all been banned by Rob & the E*POWAH elite style council - there are obviously no Australians or Frenchmen on that council. Any more mention & you’ll be subjected to extreme ridicule and further unspecified bollocking.small speedo.if a lake on the way
You forgot your rubber duckie. How else are you going to inflate your inflatable spare frame?Chainsaw. Winch . Extraction rope. Extendable stretcher . Emergency Drone. Cones . 2 Warning Triangles. Spare cranks. Three spare telescoping wheels. Inflatable emergency frame. Picnic set. Mobile triage centre. Toilet paper . Parachute. 2 matches. Spare chain for bike and chainsaw. Shackles. Zoro Mask. Spare tyre. Deep cycle leisure battery . Compact Generator. Small patch kit. Portable Tig welder. Tooth pick. Blasting caps. 15cm duct tape. 4 compact site work lamps. 6m*6m tarpaulin. Bone saw. Sterilised hand wipes. Beach towel. 4 Zip ties.
You are absolutely correct, but it's actually an inflatable breast. I've always found it calming to hold in times of crisis.You forgot your rubber duckie. How else are you going to inflate your inflatable spare frame?
They're pretty handy too as an emergency shock pump...
On my E-Sommett for example all the weight is below the half way point of the downtube,
What the hell do you need a Zorro mask for?Chainsaw. Winch . Extraction rope. Extendable stretcher . Emergency Drone. Cones . 2 Warning Triangles. Spare cranks. Three spare telescoping wheels. Inflatable emergency frame. Picnic set. Mobile triage centre. Toilet paper . Parachute. 2 matches. Spare chain for bike and chainsaw. Shackles. Zoro Mask. Spare tyre. Deep cycle leisure battery . Compact Generator. Small patch kit. Portable Tig welder. Tooth pick. Blasting caps. 15cm duct tape. 4 compact site work lamps. 6m*6m tarpaulin. Bone saw. Sterilised hand wipes. Beach towel. 4 Zip ties.
Now go back a few years, if any anyone of the current ebikes was the only one available I bet it would be the best thing ever.I think the problem is (and same with normal bikes) very few of us have the opportunity to try multiple bikes, with different motors and batteries, aside form all the different geometry and wheels sizes combos. Even if you do get to try a few, testing them for long enough on familiar terrain is going to be even harder to do.
There is no one bike that is better than everything else fro everyone out there.
I personally found my wonder woman costume too compromisingWhat the hell do you need a Zorro mask for?
Here's a comparison between Shimano 500Wh integrated vs external. It's not much of a difference in how high the weight is sitting. The internal design doesn't look any worse.Regardless of overall weight, weight placement is the most critical element of EMTB design, as this is what effects the riding characteristics, the suspensions performance, and handling of the bike.
Too many EMTB's have sacrificed this at the alter of designers trying to make the bikes look like normal bikes, which is a waste of time IMO as no EMTB looks anything like a normal bike.
Putting a load of weight further up the down tube is about the most stupid thing you can do on any bike, it makes it harder to pop up, flop into turns, and makes the front suspension behave like it shouldn't, particularly in terms of diving into the mid stroke too quickly.
In many frame designs, it also means the head tube grows to accommodate the fisted downtube, meaning compromises have to be made that knock on to other areas of frame design.Look at the new Meridas for example, and how high the top of the head tube is as a result of the frame design, meaning its harder to weight the front end when riding.
In an ideal world you want all the weight on the bike as low down and centralised as possible, and that includes the suspension components.
On my E-Sommett for example all the weight is below the half way point of the downtube, which is one of the main reasons it rides so well, whereas take the Mondraker Level for example, and see where the weight is.
Only Specilized and Whyte have really though about this with integrated batteries, but tilting the motors and allowing the bottom of the batteries to sit in front of the motors and as low as possible, but even then due to the extra length of the batteries compared to the external ones the weight still sits higher up than ideal.
All I care about is how the bike rides, not how it looks, seems silly to spend 5k on something that is better to look at than ride to me.
Interested in hearing what all this stuff you carry is.
I'm completely self sufficient for pretty much every mechanical eventuality carrying 400g of spares/tools on the bike and my phone, cash and a snack in my pocket.
I don't ever carry water on rides of under 2 hours (actual riding time) few proper (hilly) emtb rides will manage over that on a 500wh battery.
I'd take water in a hotter climate. but even then probably only about a litre tops and just have a big drink before and after the ride
That handle bar repair job is awesome!Yes external batteries are 'convenient' - however from a purely design point of view internal looks nicer IMHO. However, when it comes to engineering, having a tube that does not have bits cut out to allow a battery to be partially hidden it will be stronger for a given weight. I think Speshy has done a reasonable job and swapping batteries only takes a minute or so to drop the old one and fit a replacement. I forking HATE the lock system on my Scott.
To have 2 smaller internal batteries as @Eddy Current showed in one of his masterpieces. I would however want to run numbers as to size vs output - 2x 400Wh or similar with a nice round profile would possibly work. However, it would be a design with a bottle cage INSIDE the frame triangle .... those on the front of the main tube are forking useless.
About @steve_sordy and his backpack .... da-aum. Did a 7 hour ride the other day and went out with 2 bottles - 1 in the rack and 1 in my shirt pocket.
Not a backpack wearer as they just make me overheat and dynamically, I carry enough weight myself without carrying more up high on my back. Saturdays ride had a small seat pack with a gas bottle, some self adhesive patches, chain tool with a couple spare missing links, a roll of electrical tape and a few zip ties. Taped to the frame was a spare tube wrapped in a section of an old one to make a big patch if I ripped a sidewall.
On a similar ride I crashed hard breaking my bars - was able to ride 60km with the broken bars to finish the ride.
How lucky was it that he found an old handlebar to fasten to the rustic wooden one he broke.That handle bar repair job is awesome!
