Motors · Specialized
Specialized · Turbo Full Power (Levo Gen 3)
Specialized 2.2
Brose Drive S Mag-based, used on Levo Gen 3 (2022-2024). Belt drive, dual sprag clutches. Quiet, 410% max assist, MicroTune in 10% steps.
Torque
90 Nm
Rated power
250 W
Peak (claimed)
565 W
Peak (measured)
500 W
Weight
2.98 kg
Voltage
36.0 V
EMTB Forums verdict
Specialized 2.2 is the Brose-built Turbo Full Power motor that ran the Levo Gen 3 platform from 2022 through 2024, sitting firmly in the full-power trail-and-enduro tier. The numbers: 90 Nm nominal torque, 565 W claimed peak, 250 W rated, 36 V architecture, 2.98 kg on the scales, and 410% max assist parcelled out through MicroTune in 10% steps. It is a belt-drive unit with dual sprag clutches, derived from the Brose Drive S Mag, and it replaced the older 2.1 platform when the Gen 3 chassis landed in early 2022. Rob Rides EMTB summed up the launch reception by calling it the smoothest 90 Nm motor and the quietest both climbing and descending, and three years on that framing has largely held.
The numbers. Specialized claims 90 Nm and 565 W peak; independent dyno work pulls closer to 500 W sustained, so there is roughly a 12% gap between marketing peak and what the motor will hold under load. Note the tier split that DylanJM flagged: the 2.2 platform has shipped in 50 Nm, 70 Nm and 90 Nm tunes depending on bike spec, with the full 90 Nm reserved for Comp and above. From 2023 onward, Specialized began shipping units badged as 2.2 Custom Rx Trail Tuned, which one Expert owner noted as a firmware-level retune rather than new hardware — flatter delivery, less aggressive ramp in Trail. OTA firmware via MasterMind TCU has refined cadence response across the lifecycle without changing the headline 90 Nm/565 W figures.
Character and feel. The defining trait is quietness and a near-zero drag signal above assist cut-off, a function of the belt primary and sprag clutches. One owner reports happily spinning 30 km/h on flat tarmac at ~120 rpm cadence, which speaks to how cleanly it freewheels past the 25 km/h limit. nervado describes the 90 Nm output as plenty for most trail riding, and in efficiency benchmarking sprousaTM places the 2.2 in the same competitive cluster as Bosch Gen 4, Bosch Gen 5, Shimano EP801 and Avinox M2S. Trail mode in MicroTune is where this motor earns its reputation: 10% support increments let you dial 30/40/50% rather than jumping between presets.
Compatibility and ecosystem. The standard pairing is the Specialized M3-700 internal pack at 700 Wh, with a 160 Wh range extender bottle bringing total capacity to 860 Wh. Control runs through the Specialized TCU (or MasterMind TCU on higher trims) with a 10-LED state-of-charge strip and 3-LED ride-mode display, plus ANT+ and Bluetooth, as one detailed spec dump confirms. Firmware updates run through the Specialized Mission Control app. Note for tinkerers: Repsol confirms BLEvo does not work with 2022 Gen 3 MasterMind bikes, so third-party tuning is closed off. Standard Boost 148 rear, ISIS-style interface, 55 mm chainline.
Reliability and known issues. The honest weak spot is the belt and bearing assembly under hard, sustained Boost use. BikeBert mentions a freshly rebuilt motor on his Gen 3, which echoes a broader pattern of mid-life rebuilds around the 3,000-5,000 km mark — Specialized has handled most under warranty. Common error codes are heat-related cutouts on prolonged 90 Nm climbs above 28°C ambient. MasterMind firmware has resolved earlier complaints about laggy ramp-in, though full-power-from-zero remains slightly softer than Bosch CX Gen 5 or Avinox M2S.
Bikes you'll find it on. The two flagship homes are the Specialized Levo 2025 (160/150 mm trail-enduro, now discontinued with the Gen 4 launch) and the Specialized Kenevo 2024 (180/180 mm park-enduro, also discontinued). The Kenevo runs the same 90 Nm tune but with a heavier flywheel-feel firmware profile suited to steep, slow tech. BikeBert's S4 Levo Expert build is a useful reference point for what these chassis accept: Fox 38 Grip2 170 mm, Smashpot coil, Ohlins TTX22M with Cascade links, all running off the stock 2.2 and 700 Wh pack.
Verdict. The Specialized 2.2 suits riders who prioritise quiet, smooth, low-drag delivery on flowing trail and accept that absolute peak watts trail the 2026 generation by 30-40%. The genuine trade-off is the closed firmware ecosystem: no BLEvo, no third-party tunes, you ride what Specialized ships. Superseded by the Specialized 3.1 on the Gen 4 Levo platform in 2025; the 2.2 remains in service on existing Gen 3 frames with ongoing parts and warranty support.
Bikes running this motor · 2
