Bike Finder · Specialized
Specialized Levo 4 Alloy
Specialized
Levo 4 Alloy 2026
CurrentFull Power · TrailCurrent · 7.6/10iFreshness 7.6/10
Full-power 160/150mm mullet trail eMTB with Specialized 3.1 motor (101Nm/666W std; 111Nm/720W S-Works), 840Wh battery, Fox Genie shock, 12-point adjustable geometry
Motor
Specialized 3.1 · 105Nm · 810W
Battery
Specialized M50-840 · 840Wh
Travel F/R
160/150mm
Wheels
MX (29F / 27.5R)
Frame
Aluminium
Weight
26.05 kg
Price
From £4,799
View the Specialized Levo 4 Alloy on Specialized’s site
Specialized Levo 4 Alloy 2026
From £4,799
EMTB Forums verdict
The Specialized Levo Alloy 2026 (the aluminium variant of the Levo Gen 4 platform) is the brand's mainstream full-power trail eMTB. Headline numbers: 160mm fork, 150mm rear, Specialized 3.1 motor at 105Nm with a 810W peak (post-OTA tune; 666W and 101Nm standard) and a 3.15kg motor mass, a side-load removable 840Wh M50 battery, 64.5 degree head angle and reach 407 to 535mm across six S-series sizes (S1 to S6), mullet 29/27.5 wheel layout and a 12-position adjustable geometry system. The Levo platform has the strongest forum signal of any eMTB on sale: @Idlefrog rates the Levo 4 motor at "10% more powerful" than Bosch Gen 4 (666W vs 600W) with a "12% larger" 840Wh vs 750Wh battery.
Drive system and range. The Specialized 3.1 motor is the brand's full-power flagship: 101Nm/666W standard, lifted to 111Nm/720W on S-Works and 105Nm/810W peak post-OTA firmware update. The 840Wh M50 battery is removable (side-load) and supports a 280Wh range extender. Mission Control app integration is mature, with Smart Control auto-tuning ride duration to battery percentage, Dynamic MicroTune electronic mode and Class 1/Class 3 toggle. @Mikerb, a 75-year-old rider on a 2025 Levo Comp Gen 3, reports a 25-mile/1,800ft country ride finishing with 50% battery remaining (Eco 40/60, Trail 70/100, Turbo 100/100 settings).
Geometry and handling. 64.5 degrees up front in stock setting, adjustable from 63.5 to 65.5 degrees via offset headset cups. Reach steps cleanly: 407 (S1), 435 (S2), 455 (S3), 480 (S4), 505 (S5), 535 (S6). Chainstays are 435mm short with the Horst-link flip chip set to short, or 444mm long with the chip flipped: Specialized has now decoupled chainstay length from BB height, a meaningful upgrade over Gen 3. BB height drops 6mm in the shock-mount low position. Three independent adjustments give 12 combined settings. Wheelbase tops out at 1323mm on S6. Mullet 29/27.5 is standard.
Build and value. The gold spec lists no trims; Specialized historically prices the Levo Alloy from approximately GBP 5,800 (Comp Alloy) up to GBP 8,000 (Expert Alloy). Build kit pairs a RockShox or Fox 36-class fork with the Fox Genie shock (a new e-bike specific Fox unit), SRAM Eagle 70 or GX AXS Transmission and SRAM DB8 or Code-tier four-piston brakes. The SWAT downtube storage with magnetic pouch is a Specialized exclusive. Standout: full-power 105Nm motor, 840Wh battery, 12-point geometry adjustment and SWAT storage on an aluminium chassis. Questionable: the alloy frame is heavier than the carbon Levo (Gen 4 alloy typically lands at 24kg system weight vs 22kg for carbon).
Community-verified strengths.
  • Motor and battery class-leadership. @Idlefrog documents the 666W/840Wh advantage vs Bosch Gen 4.
  • Real-world range. @Mikerb's 25-mile/1,800ft ride at 50% remaining demonstrates the 840Wh's reach with disciplined mode mapping.
  • Affordable suspension tuning. @Ou812 reports a USD 70 Evo link gives 13% progression vs Cascade link's 30% at USD 370, with the Levo 4 platform supporting 230x62.5mm shock geometry.
  • Price reduction. @Zimmerframe reports the Levo R S-Works MSRP cut from USD 15,650 to USD 11,500 in the US/Canada; the alloy trims are expected to see comparable softening.
Caveats and known gripes.
  • Weight on alloy. @Jeff McD reports a stock 2024 Levo Comp Gen 4 alloy S frame at 54.2lb (24.6kg); the carbon Gen 4 typically lands 1.5 to 2kg lighter.
  • Six S-series sizes confuse buyers. S1 through S6 maps roughly to XXS through XXL but pencil-and-paper conversion is essential; confirm reach against your existing bike.
  • Mullet only. 29/27.5 is fixed; full 29in is not an option without aftermarket conversion (S1 supports 150mm fork only).
  • SRAM Eagle 70 mechanical at entry trims. AXS Transmission is reserved for higher trims; mechanical T-Type is the entry-level spec.
  • Push long-shock kit unavailable. @FirstAscent notes Push does not make a long-shock kit for the Levo; tuners chasing aftermarket shock options have a narrower path than on rivals.
  • Specialized 3.1 motor maturity. The 3.1 is newer than the well-mapped Bosch CX Gen 5; long-term reliability data is still maturing.
Verdict. The 2026 Levo Alloy is the most polished full-power trail eMTB on sale at the alloy price point, with the Specialized 3.1 motor, 840Wh removable battery, SWAT storage, 12-point geometry adjustment and a six-size range that fits riders from 1.55m to 2.00m. It suits riders who want Specialized's mature ecosystem and the world's deepest forum knowledge base behind them. Buyers chasing the lightest possible system weight, the most powerful motor (DJI Avinox M2S at 150Nm), or a more aggressive 170mm-plus enduro envelope should look at the Specialized Kenevo, Olympia Hekton or Crussis E-Full 12. Production status: current.
💬 Forum discussion
Specialized Gen 4 Levo - Official Thread
2.4k replies · 392.4k views · last reply 2 weeks ago
Join the discussion →
“As a Gen 3 owner, I refuse to drink the Specialized Kool-Aid. There's nothing “Super” about the Gen 4. It’s overhyped, overweight and late to the party. Pretty disappointing, to be honest. I’ll keep my current pimped-out Levo with its…”
— BikeBert · ♥ 21 · most-liked post
OWNERS’ REPORT
Specialized Levo 4 (2025+) — what owners actually know
7,850 posts · 570 owners · data through Jun 2026
4Battery-nest disconnects and dowel rattle (THE Gen 4 cluster) - fixed by the spring-loaded cradle · typical onset: First months; rough-terrain dependent
3New-bike rattle chasing beyond the nest (SWAT, display, cables, bolts) · typical onset: First weeks
0No frame-issue cluster in 14 months
'The best Turbo Levo ever made, and I say this having owned all the previous models' - bought as a 25%-off demo
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Frame
M5 asymmetric aluminium front + rear triangle, SWAT downtube storage, Horst-link pivots, S1 small size adds 150mm fork option
Bike geometry diagram
SS1S2MS3LS4XLS5S6
Toptube578 mm599 mm627 mm655 mm689 mm
Reach450 mm407 mm435 mm475 mm455 mm500 mm480 mm525 mm505 mm535 mm
Stack620 mm609 mm618 mm630 mm626 mm640 mm638 mm650 mm652 mm667 mm
Seattube390 mm405 mm425 mm445 mm465 mm
Chainstay446 mm435 mm435 mm448 mm435 mm453 mm435 mm453 mm435 mm435 mm
Headtube Angle63.5°64.5°64.5°63.5°64.5°63.5°64.5°63.5°64.5°64.5°
Seattube Angle (eff)77°77°77°77°77°77°77°77°77°77°
BB Drop35 mm29 mm29 mm35 mm29 mm35 mm29 mm35 mm29 mm29 mm
Wheelbase1255 mm1200 mm1280 mm1223 mm1305 mm1254 mm1330 mm1286 mm1323 mm
Headtube95 mm103 mm117 mm132 mm149 mm
BB Height350 mm350 mm350 mm350 mm350 mm350 mm
Standover753 mm754 mm753 mm758 mm761 mm
Front Centre809 mm765 mm832 mm788 mm852 mm819 mm877 mm851 mm888 mm
FC:RC1.811.761.861.811.881.881.941.962.04
Geometry read
Computed from this bike's geometry and spec — reach, wheelbase, chainstay, head and seat angles, travel, motor, battery and weight — and worked out per size, because a fixed chainstay can make an S and an XL feel very different.
Size
High-speed stability
64
Composed enough for fast trails (1305mm, 63.5°) without feeling like a barge.
Playfulness
30
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
77
Front-long in L: 852mm front centre on 453mm stays (FC:RC 1.88). Planted and composed; rewards a forward, attacking stance.
Technical climbing
59
Climbs well — a 77° seat keeps the front planted, with 105Nm on tap. That's 4.0 Nm/kg and ~28 W/kg of bike weight.
Watch out forNot a flickable, playful bike at 26.05kg — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Trail bikes (from 213 bikes in the database)
Weight26.05 kg3.1 kg heavier than typical
Battery840 Wh133 Wh more than most
Motor torque105 Nmabout average torque
Value for money48/100from £4,799 · comparable bikes ~£4,699
⚙️ Adjustable geometry: this frame has a high/low setting — low drops the BB and slackens the head angle for more descending stability; high lifts the BB and steepens slightly for clearance and a perkier, more playful feel.
Trims · 2
Alloy
£4,799
Comp Alloy
£5,499
MotorSpecialized 3.1 · 105 NmSpecialized 2.2 · 105 Nm
BatterySpecialized M50-840 · 840 WhSpecialized M3-700 · 700 Wh
Travel F/R160/150 mm · all trims
FrameAluminium · all trims
ForkMarzocchi Bomber Z1, 29", S2-S6: 160mm, S1: 150mm, sweep adjust compressionFox Float 36 Rhythm 160mm, GRIP damper, 44mm offset
ShockMarzocchi Bomber Inline, EVOL LV air sleeve, rebound adjust, 210x55mmFox Float X Performance with Specialized Genie, 210x55mm
HeadsetEccentric upper headset cups for angle adjustment (+1°/0/-1°)Specialized offset headset
StemAlloy Trail Stem, 35mm bar boreAlloy Trail stem
HandlebarSpecialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, S1-S2: 780mm width/30mm rise, S3-S6 800mm width/50mm riseSpecialized 6000-series alloy 800mm
GripsSpecialized TrailSpecialized Trail Grip
SaddleBody Geometry Bridge Saddle, steel railsSpecialized Bridge Comp
SeatpostTranzX dropper, 34.9mmX-Fusion Manic dropper 34.9mm
BrakesSRAM DB8 StealthSRAM Maven Bronze 4-piston
Rear derailleurSRAM Eagle 70 Transmission, 12-speedSRAM Eagle 90 T-Type
CrankSRAM S1000 Crankset, ISIS Interface, Integrated Guard, 55mm Chainline, 155mmSRAM S1000 155mm 34T
ShiftersSRAM 70 trigger, 12-speed, single clickSRAM GX Eagle trigger
CassetteXS-1270, 12-speed, 10-52tSRAM XS-1270 Transmission 10-52T
ChainSRAM Eagle 70 T-Type Flattop ChainSRAM GX Eagle 12-spd
DrivetrainSRAM Eagle 70 Transmission, 12-speed; SRAM S1000 Crankset, ISIS Interface, Integrated Guard, 55mm Chainline, 155mm; SRAM 70 trigger, 12-speed, single click; XS-1270, 12-speed, 10-52t; SRAM Eagle 70 T-Type Flattop ChainSRAM Eagle 90 T-Type mechanical 1x12
WheelsSpecialized hookless alloy, 30mm inner width, 28 hole front / 32 hole rear, tubeless ready (29" front / 27.5" rear)Specialized 30mm alloy mullet
TyresButcher, GRID GRAVITY casing, GRIPTON T9 compound, TLR, front 29x2.4 / rear 27.5x2.4Specialized Butcher GRID GRAVITY T9 29x2.3 / Butcher GRID TRAIL T9 27.5x2.3
Weight26.08 kg26.05 kg
Price£4,799£5,499
Rides similarly
Spot a mistake?
