Bike Finder · Specialized
Specialized Turbo Levo
Specialized
Turbo Levo 2023
DiscontinuedFull Power · TrailLegacy · 0/10iFreshness 0/10
Motor
Specialized 2.2 · 90Nm · 565W
Battery
Specialized M3-700 · 700Wh
Travel F/R
160/150mm
Wheels
MX (29F / 27.5R)
Frame
Full carbon / Aluminium
Weight
22.55 kg
Price
From £4,900
View the Specialized Turbo Levo on Specialized’s site
Specialized Turbo Levo 2023
From £4,900
EMTB Forums verdict
The 2023 Turbo Levo is the third-generation (Gen 3) full-power Levo, a carryover of the platform Specialized launched in late 2021. It pairs the Brose-derived Specialized 2.2 motor (90Nm, 565W) with a 700Wh M3-700 battery across every trim, and runs a dedicated mixed-wheel chassis with 160mm up front and 150mm out back.
Geometry is the headline: the carbon frames offer six settings, with a flip headset cup swinging the head angle from 63 to 65.5 degrees and a flip chip moving the BB 7mm either way. Specialized's S1-S6 sizing lets you pick reach and stability independently of inseam. The alloy frames keep the BB flip but drop the adjustable head tube.
The range spans the alloy SX/NX-equipped base bike up to the Magura MT7 and Fox Factory S-Works, so there is a Levo for most budgets, all sharing the same motor and battery. It remains one of the most polished full-power trail eMTBs of its era.
Note that this Gen 3 Levo was superseded by the Gen 4 Turbo Levo (2025), which moved to a new motor and frame. The 2023 bike is now discontinued but well supported, with the Range Extender available to push the 700Wh pack further.
Geometry read
Size
Descending
64
A solid all-round descender (64.5° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
72
Short 442mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
98
Rear-long with a planted front in S3 (FC:RC 1.77) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
76
Specialized 2.2 and a steep 76.7° seat angle keep the weight planted over the front — a proper winch. 565W of peak power and 90Nm of torque — a strong full-power motor.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
Watch out forNo major red flags in the S3 geometry.
How it stacks up vs other Full Power · Trail bikes (from 248 bikes in the database)
Weight22.55 kgabout average weight
Battery700 Whabout average capacity
Motor torque90 Nm8 Nm below average
Value for money49/100from £4,900 · comparable bikes ~£4,860
💬 Forum discussion
2019 Turbo Levo Owners Thread
1.9k replies · 813.3k views · last reply 68 months ago
Join the discussion →
“A thread for owners of the 2019 Levo. Post your pics and rides and feedback ? First proper ride today.”
— Rob Rides EMTB · ♥ 29 · most-liked post
OWNERS’ REPORT
Specialized Levo Gen 3 (2022-24) — what owners actually know
7,274 posts · 1,207 owners · data through Jun 2026
5The rattle cluster - battery sleeve, FSA headset play, cables · typical onset: First 200km
3Charge-port door fragility · typical onset: From new
3Frame cracks - small but real cluster, handled well · typical onset: Within 2 years
Gen 3 Expert at 7,000+ miles and 150 charge cycles, zero motor or battery issues - high-cadence rider who reads the failure threads daily and shrugs
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
S1S2S3S4S5S6
Reach412 mm432 mm452 mm477 mm502 mm532 mm
Stack605 mm617 mm626 mm635 mm644 mm653 mm
Seattube380 mm390 mm405 mm425 mm445 mm465 mm
Chainstay442 mm442 mm442 mm442 mm442 mm442 mm
Headtube Angle64.5°64.5°64.5°64.5°64.5°64.5°
Seattube Angle (eff)78°77.2°76.7°76.2°76.2°76.2°
Wheelbase1179 mm1200 mm1225 mm1255 mm1284 mm1318 mm
Headtube105 mm105 mm115 mm125 mm135 mm145 mm
BB Height352 mm350 mm350 mm350 mm350 mm350 mm
Standover752 mm776 mm783 mm787 mm788 mm790 mm
Front Centre737 mm*758 mm*783 mm*813 mm*842 mm*876 mm*
FC:RC1.671.711.771.841.901.98
Trims · 6
Alloy
£4,900
Comp Alloy
£5,750
Comp Carbon
£8,250
Expert
£8,750
Pro
£12,000
S-Works
£12,499
MotorSpecialized 2.2 · 90 Nm · all trims
BatterySpecialized M3-700 · 700 Wh · all trims
Travel F/R160/150 mm · all trims
FrameSpecialized M5 premium alloy, BB height adjust, S-Sizing, internal cable routing, 150mm travel, 148mm spacingSpecialized M5 premium alloy, headset adjust, BB height adjust, S-Sizing, internal cable routing, 150mm travel, 148mm spacingFACT 11m full carbon, geo adjust head tube, geo adjust horst pivot, 148mm spacing, 150mm travelFACT 11m full carbon, geo adjust head tube, geo adjust horst pivot, 148mm spacing, 150mm travelFACT 11m full carbon, geo adjust head tube, geo adjust horst pivot, 148mm spacing, 150mm travelFACT 11m full carbon, geo adjust head tube, geo adjust horst pivot, 148mm spacing, 150mm travel
ForkRockShox 35 Silver, 35mm stanchion, Turnkey damper, S1: 150mm travel, S2-S6: 160mm travelFox Rhythm 36, S1: 150mm travel, S2-S6: 160mm travelFox 36 Rhythm, 29", 44mm offset, Grip damper, S1: 150mm, S2-S6: 160mm travelFox 38 Performance Elite, Grip 2 damper, 29", 160mm travel, 44mm offsetFox 38 Factory, Grip 2 damper, 29", 160mm travel, Kashima, 44mm offsetFox 38 Factory, Grip 2 Damper, 29", 160mm Travel, Kashima, 44mm Offset
ShockRockShox Deluxe Select R, rebound adjust, S1: 52.5x210mm, S2-S6: 55x210mmS1: FOX DPS Performance Series, 3-position lever, rebound adjust, 52.5x210mm; S2-S6: FOX FLOAT X Performance, LSR, 2-position lever, 55x210mmFOX FLOAT X Performance, LSR, 2-position lever, 55x210mmS2-S6: Fox Float X2 Performance Elite series, 210x55mm; S1: Fox Float DPS Performance Elite series, 210x52.5mmFox Float X2 Factory, Kashima, 210x55mmFox Float X2 Factory, Kashima, 210x55mm
StemAlloy Trail Stem, 35mm bar boreAlloy Trail Stem, 35mm bar boreAlloy Trail Stem, 35mm bar boreAlloy Trail Stem, 35mm bar boreDeity, 35.0mmDeity, 35.0mm
HandlebarSpecialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm widthSpecialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm widthSpecialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm widthSpecialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 800mm, 35mm clampRoval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mmRoval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
GripsSpecialized Trail GripsSpecialized Trail GripsSpecialized Trail GripsDeity GripsDeity GripsDeity Grips
SaddleBody Geometry Bridge Saddle, steel railsBridge Comp, Hollow Cr-mo rails, 155/143mmBridge Comp, Hollow Cr-mo rails, 155/143mmBridge Comp, Hollow Cr-mo rails, 155/143mmBridge, 155/143mm, Hollow Ti-railsBridge, 155/143mm, Hollow Ti-rails
SeatpostTranzX dropper, 34.9mm (S1: 100mm, S2: 125mm, S3: 150mm, S4-S5: 170mm, S6: 200mm)X-Fusion Manic, remote SLR LE lever, 34.9mm (S1: 100mm, S2: 125mm, S3: 150mm, S4/S5: 170mm, S6: 190mm)X-Fusion Manic, remote SLR LE lever, 34.9mm (S1: 100mm, S2: 125mm, S3: 150mm, S4/S5: 170mm, S6: 190mm)OneUp Dropper Post-V2, MMX lever, 34.9mm (S1: 120mm, S2/S3: 150mm, S4: 180mm, S5/S6: 210mm)Bike Yoke Revive dropper, 34.9mm (S2/S3: 160mm, S4/S5: 185mm, S6: 213mm)RockShox Reverb AXS, 30.9mm, 1X remote (S1: 100mm, S2: 125mm, S3: 150mm, S4-S6: 170mm)
BrakesSRAM Guide RE, 4-piston hydraulic disc (front S1-S3: 200mm, S4-S6: 220mm; rear 200mm)SRAM Code R, 4-piston hydraulic disc (front S1-S3: 200mm, S4-S6: 220mm; rear 200mm)SRAM Code RS, 4-piston hydraulic disc (front S/M: 200mm, L/XL: 220mm; rear 200mm)SRAM Code RS, 4-piston hydraulic disc (front S/M: 200mm, L/XL: 220mm; rear 200mm)SRAM Code Silver Stealth, 4-piston hydraulic disc (front 220mm, rear 200mm)Magura MT7, 4-piston, Loic lever blade, 203mm rotor front and rear
Rear derailleurSRAM SX Eagle, 12-speedSRAM GX Eagle, 12-speedSRAM GX Eagle, 12-speedSRAM GX Eagle AXS, w/ battery coverSRAM X0 Eagle TransmissionSRAM XX1 Eagle AXS
CrankPraxis Forged/Custom Offset/ISIS Spindle Interface, 160mmPraxis Forged/Custom Offset/ISIS Spindle Interface, 160mmPraxis Forged/Custom Offset/ISIS Spindle Interface, 160mmPraxis Forged/Custom Offset/ISIS Spindle Interface, 160mmPraxis Carbon/Custom Offset/ISIS Spindle Interface, 160mmPraxis Carbon/Custom Offset/ISIS Spindle Interface, 160mm
ShiftersSRAM SX Eagle, 12-speedSRAM GX Eagle, trigger, 12-speedSRAM GX, trigger, 12-speedSRAM GX Eagle AXS ControllerSRAM AXS POD ControllerSRAM Eagle AXS Rocker Paddle
CassetteSRAM NX Eagle, 12-speed, 11-50tSRAM XG-1275, 12-speed, 10-52tSRAM XG-1275, 12-speed, 10-52tSRAM XG-1275, 12-speed, 10-52tSRAM X0 Eagle Transmission Cassette, 12-speed, 10-52tSRAM XG-1299, 12-speed, 10-52t
ChainSRAM NX Eagle, 12-speedSRAM NX Eagle, 12-speedSRAM NX Eagle, 12-speedSRAM GX Eagle, 12-speedSRAM X0 Eagle Transmission Flattop ChainSRAM XX1 Eagle, 12-speed
DrivetrainSRAM SX Eagle, 12-speed; Praxis Forged/Custom Offset/ISIS Spindle Interface, 160mm; SRAM SX Eagle, 12-speed; SRAM NX Eagle, 12-speed, 11-50t; SRAM NX Eagle, 12-speedSRAM GX Eagle, 12-speed; Praxis Forged/Custom Offset/ISIS Spindle Interface, 160mm; SRAM GX Eagle, trigger, 12-speed; SRAM XG-1275, 12-speed, 10-52t; SRAM NX Eagle, 12-speedSRAM GX Eagle, 12-speed; Praxis Forged/Custom Offset/ISIS Spindle Interface, 160mm; SRAM GX, trigger, 12-speed; SRAM XG-1275, 12-speed, 10-52t; SRAM NX Eagle, 12-speedSRAM GX Eagle AXS, w/ battery cover; Praxis Forged/Custom Offset/ISIS Spindle Interface, 160mm; SRAM GX Eagle AXS Controller; SRAM XG-1275, 12-speed, 10-52t; SRAM GX Eagle, 12-speedSRAM X0 Eagle Transmission; Praxis Carbon/Custom Offset/ISIS Spindle Interface, 160mm; SRAM AXS POD Controller; SRAM X0 Eagle Transmission Cassette, 12-speed, 10-52t; SRAM X0 Eagle Transmission Flattop ChainSRAM XX1 Eagle AXS; Praxis Carbon/Custom Offset/ISIS Spindle Interface, 160mm; SRAM Eagle AXS Rocker Paddle; SRAM XG-1299, 12-speed, 10-52t; SRAM XX1 Eagle, 12-speed
WheelsSpecialized 29, hookless alloy, 30mm inner width, tubeless readySpecialized 29, hookless alloy, 30mm inner width, tubeless readySpecialized 29, hookless alloy, 30mm inner width, tubeless readyRoval Traverse 29 (front) / Traverse 27.5 (rear), alloyRoval Traverse Carbon 29 (front) / Traverse Carbon 27.5 (rear), DT Swiss 350 hubsRoval Traverse SL 29 (front) / Traverse SL 27.5 (rear), carbon, XD freehub
TyresFront: Butcher, GRID TRAIL, GRIPTON T9, 29x2.6"; Rear: Eliminator, GRID TRAIL, GRIPTON T7, 27.5x2.6" · all trims
Weight23.81 kg23.92 kg22.8 kg22.97 kg22.55 kg22.55 kg
Price£4,900£5,750£8,250£8,750£12,000£12,499
Rides similarly
Spot a mistake?
