• Warning!!
    UK Pedelec Law
    Worldwide Laws
Volspeed v3 problem on bosch gen 4 motor
Leighton Howard
7
Oldham
Hi , ive got a mondraker E crafty R 2020 with the bosch gen 4 motor , ive just fitted a volspeed v3 chip , which worked great for the first 20 miles , now my bike has developed a fault , the motor is kicking in and out of power every revolution of the crank , i dont have any fault codes up on the kiox display, has anyone had this problem, or could advise , ive removed the chip now and put it back to standard, but fault is still there , and speedo is running very slow to standstill , ie , still showing mph, when ive stopped for a second or so , any advice would be appreciated, or its a 100 mile round trip to get it plugged in ?
Coolaudio
14
9
Glasgow
I had similar issue, bike now at lbs, awaiting diagnosis, think its most likely speed sensor issue as I was getting intermittent error 503 and same speedo issue/motor Anyone else?
Leighton Howard
7
Oldham
Is it the volspeed v3 you have fitted ?? How long did it last ?, i dont have any faults showing on my screen ?
Leighton Howard
7
Oldham
Yes volspeed v3, had done about 30 miles, no problem, parked it up for the night, then issues started next morning
Did you remove it before taking it to the shop for diagnostics? Ive took mine of , wont be putting it back on , would rather bike be reliable ✊? Thanks
Leighton Howard
7
Oldham
Very interested how you guys get on, this is a worrying development as I'm just about to receive my V3...
Ive got my bike booked in sat for them to have a look at , i wont be putting the v3 back on if its that whats caused the fault , i will post up results when its been fixed
Rawnei
16
12
Sweden
Sorry to hear it but title is a bit misleading, sounds more like an engine problem rather than a Volspeed problem.
Leighton Howard
7
Oldham
Ok so i took bike in shop sat , he did a software update with the power upgrade, got rid of fault , only took 5 mins , think it just gliched , bike shop said everything was ok after a reset , so not a problem related to the volspeed v3 , so im going to re install it and see how it is ?
EzRyder
13
London
How did you get on refitting the Volspeed?
Terrafirma
13
I've just done a firmware upgrade with the new Tour+ mode and my Volspeed has now done over 2500KM's. A lot of people seem to blame the chip everytime they have a problem. My riding buddy has also done over 2500Km's so far and no problem with his Volspeed. I recommend it and remember you only get 12 months warranty from Bosch so having the chip doesn't impact your warranty unless something happens inside the 1st year and they wan't to blame the chip. It's scare tactics IMO the chip will not hurt the motor if you are riding as per normal. I haven't tried doing speed runs with Turbo on everyday to break the speed barrier, that's not why I chipped my bike. Simply wanted to get past 25KMh which is a stupid rule IMO.
Casaibis
10
Casaibis
10
Had the same issue, double check the wheel magnet is aligned with the indicator not the fixing nut for the sensor - fixed mine. Hopefully same for you.
Elover
56
35
Chelmsford
Hi, just tried the vol speed 3 on my 2021 mondraker e crafty. It seemed to kick in and out of power. Tried about 6 times, upped the speed on the kiox, but every time i tried power may cut off at 14mph and kick in at 17ishh for example. Anyone have this problem, as i have had to remove for now?
Elover
56
35
Chelmsford
On this model, magnet is on disc rotor. The last 2018 model i had the magnet was on spokes and yes if knocked it would not work properly, dont knoe what to do with this one... Is your magnet spoke or on disc?
Casaibis
10
Spoke mounted, sorry I can't help with disc mount sensor, not sure how to check those or if they are even adjustable. Good luck as I'm sure it will be something minor as my impression is the Vol3 seems pretty reliable.
542K
