Upgrade time, Internal routing....
Luke0770
23
11
Maidenhead
Planning some upgrades to my Jam2
Looking to upgrade my dropper post, brakes and change to e7000 switch
How easy is it to get access to the internal cable routing?
Do I have to drop the motor?
Also what length cable do I need for the e7000 switch 300mm, 400mm or 700mm?
20,498
Didn't do it on a Jam2,but another E8000 bike. The E7000 switch I used a 400mm cable which was the right length.
For my dropper it really should have been a drop the motor, which isn't that bad, it swings on the back two bolts. But I left it in and spent more time than was sensible feeding the cable through. Mine had a bash guard on the motor, so I took that off and went round the outside the motor, coming round and backup took a lot of time and patience .. You might also run short on cable going the long way round too .
Hopefully someone with a Jam2 will come along and give some "real" information :)
BackHol3
24
8
Finland
I got a new Jam2 9.6 Plus bike just recently. I cut the dropper housing too much and I had to route the housing again. It was impossible to route the "factory way"(above the motor)if you didn't want to take motor away, so I had to route the housing between the motor cover and motor and bring back up behind the motor( yes, there is a hole which lead to the seatpost).
Actually it's better this way because the cable and the housing doesn't had to make so tight turn when goes up to seatpost. In here Finland tight cable turns are bad because the freezing sub zero winter.
Luke0770
23
11
Maidenhead
I just received my new E7000 switch and it's the wrong size.
I ordered the 400mm and I needed 700mm length cable.
The 400mm is okay if the cable runs externally.
The 700mm is what you need if the cable runs internally in your handle bars.
So I have ordered a connector to join the two together and just leave the rest inside the bars
bissona
137
106
Guernsey
I replaced my dropper cable last weekend by taping the new one to the old one and pulling it through. Worked perfectly, took 1min.
Have taken the engine out a couple of times and it’s no longer a job I do out of choice!
