Trek Rail 7 upgrades
Arcadyus
20
11
WA
I’ve made a few upgrades that have made my rail even more fun than it already was, if that’s even possible.
1. Cush Core front and rear
2. Wolf tooth dropper post remote
3. XT shifter
4. Rev Grips
5. 108 point of contact hub upgrade
6. 160mm crank arms
Next I’m getting my first pair of clip in pedals. Saints with Bontrager rally shoes.
What are some upgrades you have done to your Rail?
Doug Stampfer
738
756
NZ
WTB saddle. The stock one is the most uncomfortable I've ridden in the last 30years.
Rogue (?) grips - reduced a lot of arm pump
Gotta get some tape & change the colour - that grey & maroon puts me to sleep
RAIL97
japan
My Rail9.7 upgrade:
1.Magic mary & Eddy Current
2.Charger damper upgrade
3.Crank brothers HIGHLINE Dropper(125mm)
4.XT Shifter & Derailleur
5.77 Design stem & Carbon handle bar
6.Prologo Proxim W650 saddle
7.Magura e-STOP brake
8.PNW LOAM Grip
Arcadyus
20
11
WA
My Rail9.7 upgrade:
8.PNW LOAM Grip
How do you like those brakes? I feel the stock brakes are good but obv could have more stopping power.
Doomanic
🛠️Wrecker🛠️
8,895
10,747
So far;
ODI Rogue grips
Spank Vibrocore Bars
Nukeproof Horizon pedals
Galfer 223mm front rotor
Magic Mary front tyre
Planet-X Barbieri tyre insert in the rear
Ergon SM e-Mountain saddle
Invisiframe
To do;
2021 170mm airshaft or Vorsprung Smashpot coil conversion for the forks
Damper upgrade, either FAST YariUp or Charger 2.1
Coil shock, undecided on brand, but either DVO Jade X or Ohlins TTX 22M
150 or 170 dropper post
Tempted to try;
27.5" rear wheel
35mm stem
I have both in the man-cave...
Needed;
Stabilisers... eff off @Zimmerframe
Doug Stampfer
738
756
NZ
It would be intersting to see what a 27'5 rear is like. Is it as easy as taking off my other bike & trying? I'm sure it's a boost.
My Yari seemed to bang a bit on jump landings the other day, Be good to find a remedy for that.
Doomanic
🛠️Wrecker🛠️
8,895
10,747
Ideally, you'd need a 12 speed cassette on the wheel, but with a bit of tinkering with the stops you can use an 11 speed.
Doomanic
🛠️Wrecker🛠️
8,895
10,747
I'll be fitting one as soon as TFTuned have stock...
Drewf
27
15
Can we please get the details and parts needed to do the 108 point of contact hub upgrade? Thanks!
Arcadyus
20
11
WA
Part # 552415
Part # 552414
Then just remove the rear wheel. Pull the cap off the cassette and then pull the cassette out. Put the 3 springs and pawls in the hub. Be careful the springs like to fly. You'll want to use a pick. And do them one by one. Put the spring in place the pawl in the slot. Then use the pick to depress the spring at the same time pushing the pawl down. Grease helps a ton use lots.
Drewf
27
15
Thanks for the quick reply! I have to Rail 5, so my hub is probably different that your Rail 7. Rail 7 looks like it comes with Shimano MicroSpline freehub and my Rail 5 comes with Shimano 8/9/10 freehub...I tried just pulling my cap off, but it will not budge. Sorry I know this is a Rail 7 thread...sorry for the spam.
Stanpipe
81
80
Isle of Wight - UK
My Rail 9 Upgrades (so far)........
MRP Ribbon Coil Fork (set at 160 with firm spring)
Fabric Scoop Saddle
One Up 210mm dropper
Michelin Wild Enduro F&R
Syntace Vector Carbon Bars
Race Face Chester Pedals
Sonder Love Mud 55mm stem
On order.....
Ohlins TTX 22 coil shock
Thinking about......
Rev or Deathgrips
Hope e-cranks
Philly G
695
518
New Zealand
I’m on a Large frame. 185mm Bikeyoke Revive. I’ll be putting it up for sale soon! ?
I'm wanting to run a 185mm Bike Yoke dropper on my large size Rail 7. How did you find yours fit clearance wise? No Issues? Did you have it fully slammed into the frame?
Stanpipe
81
80
Isle of Wight - UK
Stanpipe
81
80
Isle of Wight - UK
Length of post at full extension was 460mm or 490mm including mechanism at bottom. Drop is 185mm (obvs). You could work out from your current set up whether 460/490 will work to the kink in seat tube.
573K
