Levo Gen 2 Swapping from RS to Fox forks on a 2020 Levo comp
TeaAndCakes
Can anyone confirm some details about the Roval front hub. There are caps on both sides of the hub that can be removed (push fit with an o-ring) reducing the diameter from 31mm down to what appears to be just over 20mm. Is that all that needs to be done to swap from the RS Lyrik and be a compatible fit with Fox? Or do the whole assemblies remove from the hub and need replacing with different parts? Thanks for any advice ?
TeaAndCakes
I got a Fox38 and that’s the only thing I had to do.
Just in case my fox is 15QRx110 Boost. I don’t know if there are other options.
Thanks RodC, 38’s arriving tomorrow and glad I’m not heading for a fitment disappointment ?
Chad156
Atlanta, GA
For what it's worth. The base model Turbo Levo (2021) does not come with these caps. The wheels are not the Roval Traverse that are stock with the comp model. The end cap is too large to fit into the Fox 36 fork. I heard there is a specialized end cap hub insert that will slide into the wheel, but its out of stock everywhere. (Specialized EDC Bear Pawls BMB-00315OF0 Front Hub Endcap Set 19mm OD
S205900002 )
My solution was to just upgrade to a set of Roval Traverse wheel set.
