Hey
So finally taken receipt of my 2020 Comp. Its stunning.... I can’t really ride it though... the dropper post won’t hold my weight. I’m only about 70kg’s so not like I’m testing it. I can even push it down with my hands and a bit of weight on top! The lever works as it should but the dropper just doesn’t lock out firm enough.
It’s a X-Fusion Manic. Should be a medium spec one which is the 150mm. From what I read the post should also be able to go in just over 280mm. Measuring that it would reach the bolt of the top part of the rear triangle into the seat tube so says to me that this post could actually be resting on the suspension bolt which is only about 200mm down.
Has anyone experienced the non-locking dropper and also, have I got it wrong with the bolt? It does feel like the dropper can’t go any further so I am assuming it is touching. I’ve pulled it up a couple of mm so it isn’t on the bolt but it seems concerting that the two components can be touching, or is that just normal and I need to be careful?
Cheers
Cheers
