goldenc
Hi all,
Came back from a ride yesterday on my Kenevo SL with 60% battery and switched the bike off. I noticed I had some creaking from the bottom brack area so took off the cranks and chainring and cleaned and regreased everything. Seemed to fix the problem of the creaking but now the bike won't run on
I plugged the TCU in with a USB-C cable and it gives the message 'No motor check app'
When I plug in the charger it shows charging progress (got it up to 90%) on the TCU but it won't start up normally. Tried a reset also but did nothing.
I looked on the app and it says HMI permanent failure SL1-B-HS-132
Sounds pretty serious, guessing I'll just bring it to the LBS but thought I'd ask a question here first if anyone encountered something similar.
Cheers!
Cheers!
