First thing I'd try is removing and reinstalling the battery
Hi Stumpy,
Back luck day then don’t buy any lotery tickets anymore today...
Did you get this failure immediately after the chain snapped and you repaired it? If so, I can imagine that due the chain suddenly snapped a power overshoot could have caused this issue as most probarbly the sensor recognized an unexpected value. I would try a complete bike reset. Not sure how the procedure works for a 2018 model.
I have heard of a few who had issues with the Brose torque sensor and your MC indicates that you have the same issue. I think the only way now is back to your LBS, hopefully you have warranty as you will properly need a new motor
Karsten
A good LBS is so very important, when that is said I in the end I got a very good ending to my issues - I'll update the other thread but lets just say that there is a pair of brand new 29" Roval Traverse Carbon wheels on my bike now.Totally agree with your theory, I heard the motor give out a nice high pitched “whine” when the chain snapped.
The only way I know of to reset anything is via MC which I’ll try in the morning but I’ve spoken to our friend Chris @ Berkshire cycles and if all else fails he will fix or replace.
I’m already on my 4th motor (long story) plus I’ve had the brakes x 2 replaced, now swapped out for XT 8020’s, the dropper rebuilt and now swapped out for a crank bros high line and a new battery - all under warranty. ? I know you’ve had your issues with Spesh but I can’t fault their customer service here. It helps to have a LBS, like the aforementioned, who has a good relationship with Spesh too.
I’ll let you all know how I get on. Interestingly MC is not throwing the error anymore but the motor is still dead
Karsten
Good luck with the motor, It could also be a loose connection between battery and motor but they usually don't have issues with that before MY2019. My MY2018 have been absolutely perfect apart from the 29" issue, you must have gotten what we call a "Monday" model unfortunately.
Karsten
Can I just ask:????
I run an extender so tried swapping back to the factory harness but that didn’t help so I have ruled out a connection issue, but thanks for trying to help.
