andrewgc
Considering a Rail 7 Gen 2, which should have the Purion. Can someone please explain the Kiox upgrade? It that a Trek product, or aftermarket. What are the advantages? Cost?
Thank you!
Andrew
Thank you!
Andrew
Excellent. Thank you so much!Hi
Kiox is a bosch unit but the frame mount is Treks
I did the mod to my 7 but mounted it on the top of the steerer which the kiox kit you buy comes with anyway
Best advantage for me was battery percentage instead of 5 blocks
Theres other features but i tend not to use them its also handy being able to adjust your wheel size if you put a 27.5 on the rear
Kit below but obviously you would get it your side .
Bosch Kiox Retrofit Kit
<p>Bosch kiox retrofit kit, includes kiox display and holder, mounting plate, 1.5 metre drive unit cable and a control unit</p> <p>All parts come pre-assembled</p> <h4>Motor compatibility:</h4> <ul> <li>Gen 2</li> <ul> <li>Activwinstanleysbikes.co.uk
