Ok gurus! I’ve bumped to a 170mm fork from stock 160mm. If I want to retain 64.5, if I just run headset in steeper angle, what would the measurement be?
Yeah as above, at sag your only increasing the height by 7.5mm, and the 0.5 degree per 10mm is so old now, the slacker your head angle is the less the travel lift will affect it. Just get out and enjoy it!!
