RockShox Reba Front Fork travel
Matthewedwar
9
West Yorkshire
Hey, guys have a query regarding my front fork travel length. I ride a 2018 Levo FSR. The specification when I bought it said Rockshox Reba RL forks with 150mm travel. However, if you take a look at the picture I have attached it shows 130mm. Is this correct or do I have the incorrect Forks?
Gary
Old Tartan Bollocks
10,496
10,688
the internet
ignore the markings
remove aisome or all air from the fork, fully compress it and leave the red O-ring where it has been pushed to on the stanchion. Re-inflate (you did note down the pressure you run somewhere earlier?) and measure from the o-ring to seal. That's your fork's full travel.
Spesh may have fitted a longer air shaft (upping travel) in a 120/130mm fork chassis. I've no idea about spesh specifications per model but that would be my gusee if it's a 150mm fork without coresponding sag markings
khorn
980
1,054
Denmark
The Levo came in a 120 mm “short travel” version, could it be one of those?
Karsten
521K
