HaiBike with PowUnity BikeTrax Yamaha
JDJAN
Finland
Hello, As I mentioned earlier, my HaiBike FullNine 2018 came with eConnect installed. But end of 2023 eConnect stopped working. So after searching for alternatives, I found PowUnity BikeTrax Yamaha to fit my HaiBike. This has some additional features though it is subscription based for data useage.
After removing the motor, I found that eConnect had special adapter cable in use which connects to the original HaiBike cabling. Also I have front/rear lights which are controlled from the Controller and plugged to a 2 pin connector port from these Haibike cabling harness.
So its now not so straight forward to remove the eConnect and add BikeTrax..or it is not clear to me.
So has onlyone replaced eConnect with BikeTrax unit in HaiBike Yamaha motor?
If so, any help.
527K
