I assume you are talking about the motor connected to the Sun Gear, which is MG1. It cannot disconnect or freewheel, or you'll immediately go into the lowest gear. Also, in the lower gears it is being driven backwards by the plantetary gears, so you'll lose all the regenerative energy.Some clever freewheeling/clutch mechanism so Motor B can disengage when not actively shifting
And don't forget. When the Sun Gear is being driven FWD by MG1, that energy isn't just changing gear ratio. It is also a parallel power source to MG2. So both motors are driving the wheels.
I do expect losses to be slightly greater than a derailleur setup. But it will be marginal. ECVTs can be designed quite efficient. But as the technology improves. They will be able to introduce regenerative braking, and I'm guessing a 10-15% improvement in range. Which will far exceed any minor losses.Without one of those, I'd expect noticeably worse range than a comparable single motor mid drive.
It doesn't have to do ratio changes. It can be programmed to give a constant ratio. In this mode MG1 is constantly adjusted to the correct speed and direction to give a fixed cranks to wheel ratio. Depending on how well the software responds, it will feel just like a fixed speed gear.the e-CVT is doing ratio changes all the time.
