Has the fox float dps shock got high speed and low speed compression ?
What does the blue dial control and what does the black dial control ?
So it’s all to do with low speed compression and nothing to do with high speed compression ?The black one is Open Mode Adjust - provides additional adjustment for the 3 position lever.
It is recommended that you have the blue lever in medium or firm mode before adjusting the Open Mode Adjuster.
