Fox 36 upgrade to 160 from 150?
SparkleHedgehog
47
25
Coningsby, UK
So am I right in thinking the fox 36 performance forks of 150mm on my 2020 turbo Levo carbon expert use a 34 air shaft due to the fact it’s an ebike? I read that ebike fox 36 uses 34 and if so can I just buy this Fox 34 160mm air shaft to turn my 150 forks into the widely regarded better 160mm travel?
Is this the best cheapest way to upgrade my forks to make the geometry inline with the 2021 models?
thanks in advance
Pdoz
1,112
1,206
Maffra Victoria Australia
No - specialized fitted normal 36 mm forks, not ebike forks. The forks have a number on them, it's worth checking that when you order because everything gets confusing between 2019 and 2021 .
MrSimmo
1,054
987
The Trail.
thanks in advance
I did exactly that on my 2020 Levo expert with fox 36’s - bought the 160mm damper and swapped it over.
I posted a thread on it a while back with the part numbers 👍
edit: heres the post:Specialised Levo Comp 2020. More front travel? - EMTB Forums
SparkleHedgehog
47
25
Coningsby, UK
