Levo Gen 2 Error Message.
Kiwibloke
111
195
Kent
Got this error message when I turned the bike on this morning, I don't have lights attached. I'll take the bike out soon and see if all is ok, if it is how do I get rid of the message?
salko
1,241
837
SLO
You'll have to remove the motor cover on non-drive side and check if maybe a plug cap for light port has fallen out, mabe dirt has entered into the port causing short-circuit...
Kiwibloke
111
195
Kent
Ah ok thanks for that, I will need to get tools to take off the crank. Do you think it is rideable? I will give it a go but don't want to end up half way to work and everything dies on me.
salko
1,241
837
SLO
You don't need special tool to take the crank off, just 8mm alen to undo extractor bolt ...
Kiwibloke
111
195
Kent
Yeah you are talking to a dimwit here Salko, I have one of those and un-done the bolt now, but then what.It's loose and then goes tight again, I'll do some research on YouTube.
20,498
It's not too scary .. It just unwinds like a normal bolt (as in, anti-clockwise to loosen) - it's self extracting, so it might be tight to turn as it pulls the crank off as you turn.
When you put it back on - make sure it's at 180 degrees to the one on the other side or your pedal motion will be a bit strange ! :)
Because they're not "handed" (as in like pedals with one thread one way and one the other - though the actual cranks are left and right handed to accommodate the pedals correctly or your pedals unwind themselves as you ride) - the left side crank can unwind itself if it's not on tight enough.
You don't have to swing on it like a gorilla (if you don't have a torque wrench). You'll see it wind the crank all the way in then it should just feel "tight" .. on the left side I normally then give it a little extra turn just ot be safe.
Kiwibloke
111
195
Kent
Thanks Zimmerframe, I have done it now, yeah I was just unsure and being a blouse, do you know I the torque setting?
Thanks to both of you.
Kiwibloke
111
195
Kent
Oh and it all looked good in there, no dirt or moisture, I didn't reseat any cables (blouse again). I'll leave for work early and ride close to home for a bit.
20,498
Don't ask me .. I just snapped the head off my torque wrench ... now hammer .....
But I think it's 50nm if I remember correctly .. Ideally greased, though it's probably still greasy .. and absolutely no loctite.
ScottWest
123
76
Oregon
I have had this error too. Cleaned connections but that didn't solve it. Dealer ordered me a new cable, but I don't have it yet. Error went away. I assume something dried out
Kiwibloke
111
195
Kent
Just got back from work, error has gone, bike was fine both ways so I'm sure all is good, I'll get that bolt torqued correctly.
salko
1,241
837
SLO
No. Although extractor bolt is marked with 50Nm I found this too tight, spesh manual says 40Nm.
