NULevo
I'm using BLEvo these days, and noticed this message in Mission Control today . Its always a few minutes between turning off and removing the battery.
Should I be worried?
Do you get error lights come up On cpu ? Mine does . Then off and back on is usually fine after just displays that msg in mission control.
I'm hoping it's nothing to worry about
Mine has been doing it for about three weeks . Probably a couple of times a week . When i turn it on it has a red and blue flashing lights. I turn it off . Back on . and it's fine .
Me too, nothing we can do until this Corona thing is over.
I'll keep riding, my daily exercise, can't go far anyway, so will be able to get home without power if anything does happen.
If @Specialized Rider Care read this, perhaps they could advise?
Hi @NULevo - thanks for asking. This is a warning rather than an error, it's coming from the motor - the motor is effectively telling you that it didn't get an official message from the TCU to switch off before the 36V supply from the battery was lost. This could be for a few reasons: -
1) You unplugged the battery connector to charge the bike without turning the bike off first.
2) The connector to the battery was removed slightly whilst riding - hit by a stone/stick or perhaps some dirt/grit is stuck in the connector.
3) There is damage or water-based short-circuit to a cable - most likely the main power cable between the battery and motor.
By far the most likely is 1. However this is almost certainly going to happen when you stop at home and display the next time you turn the bike on. 2 is most likely to happen on a ride with some form of associated movement/impact whereas 3 will be happening more intermittently and may be accompanied by other errors where retailers will have more detailed insights.
Trust that makes sense. @NULevo I'll PM you for your serial number, it may be I can see more on the back-end but please anyone feel free to comment on this thread if you have more detail about when these errors are shown and what you feel was the driver.
@Specialized Rider Care I think I have identical issue as OP on my 2020 Levo Comp. Firstly it started couple of weeks since owning the bike (about 6 months ago) as red/blue leds flashing right after starting the bike and after rebooting everything worked fine. This error keep happening every now and then and every time after reboot the bike worked fine, also I checked in MC app while having this error and status was shown as healthy, no error or warning, so did not look as a big issue. But lately when I get this same flashing lights I also get this error/warning in MC app, I guess now it shows because MC app has been updated to include some new diagnostic features/warnings/errors.Hi @NULevo - thanks for asking. This is a warning rather than an error, it's coming from the motor - the motor is effectively telling you that it didn't get an official message from the TCU to switch off before the 36V supply from the battery was lost. This could be for a few reasons: -
