Dropper post lube
Mteam
1,789
1,726
gone
Any lightish oil seems to do the trick, if its one with an unscrew able collar, just unscrew the collar and dribble a bit of oil in, slide it up and down a few time and screw the collar back on.
Mteam
1,789
1,726
gone
What about a small amount of lithium grease?
I reckon it would be fine, I've used all sorts over the years, chain oil, lithium grease, engine oil, whatever I had to hand at the time, it all seems to do the trick really. But a lightish oil like chain oil seemed the best.
Cocodrilo
21
8
C0c0dril01962
6,145
4,676
I use wet chain lube on the dropper and shock/fork stanchions before I start on cleaning and lubeing the chain. I just let it sit on the rubber seals for a while. Once the bike comes off the stand I push the dropper down and release and wipe off...same with the shock and fork. The oil brings any dust out of the seals but also some oil remains on the shafts as they get pushed down through the seals. Once cleaned off I spray all those parts with silicone shine.
Konanige
422
336
Mendips
But of light lube after a wash up and down a few times to clean seals then make sure there's nothing on it but air when you ride!!
Edmu
17
Puerto Rico
Is this safe for carbon frames? (I read that certain grease or lube compounds expand and damage carbon fiber.)
6,145
4,676
sorry mate....no idea. No idea either why anyone would want anything carbon on an e MTB!!
