CYC Motor Cranks -- Lekkie?
Seraye
58
38
Portland
Hello,
Recently purchased a CYC Motor Stealth V3 with the Isis splined cranks. Need to replace the stock cranks as my driveside crank came loose and cannot be tightened sufficiently. Has anyone installed the Isis splined Lekkie Cranks that electrify bike sells as an upgrade for the CYC motors? Your experience? Or have you installed any of the other cranks made for the Bosch motors successfully?
Seraye
58
38
Portland
Hello,
Yes, Isis fits, and I am glad you responded to this because I forgot that I had posted this. I did end up purchasing the lekkie cranks for my CYC motor, installed them in to my x1 Stealth, which was installed on a Surly grappler frameset with a 73mm bottom bracket, and the q-factor with the Lekkies turned out to be absolutely unacceptably wide, it measured it to be about 230mm! So the lekkie cranks might be okay for a Bosch motored emtb, but unless you want a q-factor almost two inches wider-- there is no way they are a suitable replacement for the CYC cranks.
