Chain links tight and skipping after 93 miles
Shifty
249
442
Wiltshire
Noticed at 70 miles my chain kept skipping. Checked, I have a very tight link. I have oiled well before and after rides. But it’s got tighter. Did the YouTube chain twist but it hasn’t helped.
Any ideas would be appreciated?
Trance Pro 3 2019 Model
Shifty
Pukmeister
283
263
Fareham
Might need a chain breaker tool to push the rivet in/out a bit to loosen the stiff link. Either that or your supplying dealer should fix it for you under warranty.
Shifty
249
442
Wiltshire
Cheers I just found my chain tool and just as I was putting it on to the chain it decided to loosen up! Must have known the threat was coming !!!
I will take it on my next ride.
Thank you
Shifty
249
442
Wiltshire
Are you sure its the chain skipping? I thought the same but it was my rear hub starting to let go.....makes a similar clunk but louder[/QUOTE
Yes, I ran the chain backwards through the derailleur by hand and you can see where the chain wasn’t tight to the lower jockey wheel as it wasn’t bending at the link joint.
Shifty
249
442
Wiltshire
SOLVED- I used a chain link remover tool and nudged the pin with it in the tight link. It freed it.
