Canyon torque on with 29er fork
Troeyler
8
8
oslo
I am buying a tourqe on 8. Making it mullet.
Fitting a 170mm domain on it and selling the 27,5 zeb 180 fork.
Asked canyon an they replied below(is this really an issue?)
I asked this from our technical department, and even though this may technically be possible we do not recommend this. Converting the bike to 29" and changing the fork will void the warranty as we have not tested the bike with such components.
6,141
4,672
They are perfectly within their rights to deny any warranty claim for a bike modified beyond their spec. Your proposed changes will apply forces to the headset and frame that have not been tested by them so it is reasonable for them to deny any liability for subsequent failure of parts.
Huw169
39
20
Hampshire
Any company will say the same, as they are covering themselves.
Realistically though, the force changes will be non-existent.
6,141
4,672
Of course the forces on the headtube will be different if you change the angle of attack of those forces by fitting longer forks/going to 29er front. By how much would depend on the degree to which you change it. All of that is however not relevant as far as the OP is concerned. Canyon is not saying it will lead to damage, it is saying that if it did lead to damage there would be no warranty cover for that damage.
Brands do test their bikes for different configurations. Not exactly the same but for example when the Levo was sold with 150mm forks Specialized specified that 160mm could be fitted but not greater than that. Clearly the bike had been tested with 160mm back in 2019 and later in 2020 the Levo was indeed fitted with 160mm forks as standard.
2WheelsNot4
891
689
Acceptable point, only we know the forces on a headtube would have to be immense for something to give in that department, so while they can claim it, I doubt they could prove it
Huw169
39
20
Hampshire
Different, but by sod all. Which equates to nothing in the context of what the head tube is designed to do.
