Bosch NYON no wifi connection
duvaldk
Denmark
Hi.
I´ve a Bosch NYON 2020 ( FW 2.0.3.0) i can not see my own wifi networks, i´ve tried with open network and a lot of other things.
I can see my neighbours network, but NYON says its a wrong key ( i know the key for this network )
i can start up a network via an old wifi harddisk i have, then everything work perfect.
Is it a common problem with NYON ?
Silverfox Baz
28
8
Cardiff, UK
I just got the Nyon and am not having any problems connecting to WiFi. I have 2 networks and it connects to both and also shows my neighbours network.
I have had a problem, however, with Bluetooth. It connected without an problems to my phone initially but after a day it stopped connecting. I ended up having to do a Factory Reset to get it working again.
Sorry, I don’t have any suggestions regarding the WiFi issues except maybe doing a Factory Reset.
oceanskipper
44
7
North East
I’ve found that the phone needs to be “awake” for the Bluetooth to connect reliably. If my phone has been untouched overnight for example and I start the Nyon it won’t connect. I’ve also found that having the eBike connect app running (even in the background) makes a difference. With regards to WiFi have you tried in different locations OP? Also is your WiFi 2.4 or 5Ghz? Not sure if the Nyon works on 5Ghz…
537K
