Avinox Reveals its Motor Gearbox
Based on Rob's video of his convo and short ride with Canyon it doesn't sound to me like the system is at the point of development it could be ridden to that extend or they'd give anyone that level of ride. These YT'ers will say anything for views these days so I trust most very little.... That said I almost always get a little over 2k m vert from my 800w and I'd expect anything new to be that or better. If an eCVT cut my current ride duration/elevation even 10-15% at a similar weight I'd for sure stick with a derailleur.
canyon are claiming 2k metres with it. Not me. In fact I didn’t mention that at all, I didn’t even ride a Canyon?
A few of the retro randonneuring companies have started making new friction shifters, and some of the influencers in that world have been extolling the virtues of how they make you more "in tune" with your bike and require less maintenance, so that debate is still going on (albeit in a very small scale niche part of the cycling world)!
Hey, some people prefer vinyl records to streaming music, each to their own I guess.
It’s what makes us humans. 😂👍
Didn't say you mentioned that, I was replying to the previous comment saving some other YT'er said that.
Of course I did the old ass-u-me but after talking to Canyon then saying you have a ride on the new system without specifying which a person could almost think correctly it was that brands bike. I'll take that as a big old nope.
Rob wasn't talking with Canyon in the vid it was someone from Avinox. They were just using the Canyon frame as the prop.
Avinox made a big difference in the routes I take climbing and I can see this being another big jump.
Yep. Once again it will be climbing where this motor will leave other riders with derailleurs in the dust. Right now. At the bottom of a very technical climb. I pretty much have to pick a gear and stick with it the whole section. Unless you can find a point in the climb to power off and shift. You need a few seconds.
With Auto. As you climb and slow, the gear ratio will just change and you can maintain your cadence and power, and not stall out. The only time you need to back off is to prevent rock strikes with your pedals. And overrun can sort this out.
The only problem I foresee is crank timing to prevent pedal strikes. As the gear ratio changes mid pedal stroke, it will be harder to judge when the pedals at bottom dead centre, will align with an obstacle ahead.
    675K
