2022 Cube Stereo 160 SL Error 523001 / Cover
lum
7
Katowice, Poland
Ok so today my Cube arrived, and it`s not even working from begining :) I`ve tried to do some ride with assist but speed is not showing and motor is working uneven, looks like magnet issue I`ve got 523001 error , do you know is there a quick fix or I need to go to LBS ? And the second issue is the battery cover should it look like that ? The fit do not look so good...:(
jempezen
54
217
Switzerland
The battery cover should not look like that ! On my 140 TM 750 there was a small gap only on a side. I have found that you can change the position of the motor cover. Mine fit perfectly after an adjustment on the motor cover
JP-NZ
1,055
795
Christchurch - New Zealand
My gosh thats a terrible from Cube QA if they sent it like that. That battery!!!
523001 Is drive sensor error.. Magnet maybe too far from the sensor
Drive unit error - sensor system.
Error in the speed sensor of the drive unit.
Possible effects: Reduced drive unit output. Speed
display not functional.
Rob Rides EMTB
Administrator
Staff member
6,170
13,315
Surrey, UK
Battery cover isnt fit correctly. Have you tried removing it and adjusting the screw at the top of the frame?
Error code is a speed sensor issue. Check everything is aligned correctly, is there a magnet on the rear wheel near the brake rotor?
lum
7
Katowice, Poland
Thanks for response :) I`ve checked and all was in place, LBS will try to fit better the battery cover. They checked the sensor and all was okay with that but it still do not work, they even cleaned it from computer and called bosch directly. They told me they will do a swap magnet sensor from other bike...and if this do not work they will swap the motor.Will keep you updated.
lum
7
Katowice, Poland
A little update:
So I`ve ridden ebike about 150km and from around 50km it started to make some creaking noises out of back frame / engine. I gave the bike to LBS and right now it seams like I will be getting a new engine :O compared to my old yamaha motor 5000km without issues and still running it`s a nice score, it`s a bit sad cause my ebike spended more time in LBS than in my hands :)
525K
