2021 vrx suspension settings
Vinny31
Geogre3134!#
Anyone care to share their suspension settings?
I'm currently running 52psi front and 160 psi rear which is giving 25% sag front and rear.
I'm 74kg in my riding gear and wondering how my settings compare as it feels super plush and comfortable atm, if I run higher pressures I'm getting bounced around and sometimes off the trails.
thebarber
986
596
Norfeast
With more pressure you'll need a tad more rebound to calm it down
Plush is good
sag around 25% front and 30% rear is a good start
CJaMTB
400
374
Dartmoor
Don't forget that it'll depend entirely on which model of bike, and therefore which fork and shock, people have. The sag settings mentioned above are a good starting point, but most manufacturers these days will have recommended pressures and settings for given weights, which are normally within one or two clicks of being spot on! Can't tell you mine as I only just got the bike and have non-standard shock and fork fitted, but will update you after a few sighting rides, once it's all dialled in.
Vinny31
Geogre3134!#
Does anyone know how many volume spacers the zeb ultimate comes fitted with from new on a 2021 E-sommet vrx?
Also how many spacers are standard on the rear shock?
Cheers
499K
