2019 esommet speed cable routing.
L1 UUD
Barnard Castle
Hi
Does anyone know the easiest way to remove the speed sensor cable from the rear chainstay ? I need to change my chainstays and the cable routing looks like a right faff. Do I need to thread it all the way from the display ? If so does that mean removing covers, battery terminals etc etc ?
Any advice gratefully received.
davosaurusrex
568
335
Worthing
It plugs directly into one of the terminals on the motor. With the plastic motor cover removed it's pretty easy to pull through and back through the new stays isn't hard either, put a stiffer bit of cable through as a draw wire
499K
