Sold 2018 Specialized S-Works Levo: $5,999
GeorgesEBike
198
355
Verdi, NV
Bike / Product Year: 2018
Manufacturer: Specialized
Model: S-Works Levo
Asking Price: $5,999
Description: For sale is my size large 2018 Specialized S-Works Levo. I purchased it brand new from Mikes Bikes Pleasanton March 07, 2019. Includes warranty until March 07, 2021. Has upgraded 2019 Carbon Roval Traverse SL 29” wheels with the DT Swiss 240 Hubs. Also has upgraded Bike Yoke Revive 185mm Dropper Post. Bike is in excellent condition and has proven very reliable.
$5,999.00
Men's S-Works Turbo Levo FSR Carbon 6Fattie/29 | Specialized.com
TECHNICAL SPECIFICATIONS
DRIVETRAIN
CHAIN: SRAM XX1, 11-speed w/ PowerLink
CRANKSET: Custom alloy crankarms
SHIFT LEVERS: SRAM XX1, 11-speed
CASSETTE: SRAM XG1199, XD, 11-speed, 10-42t
CHAINRINGS: Forged steel, 32T
REAR DERAILLEUR: SRAM XX1, 11-speed
SUSPENSION
REAR SHOCK: RockShox Monarch RT3, Rx Trail Tune, AUTOSAG, rebound and 3-position compression adjust, 197x48mm
WHEELS
FRONT HUB: Roval Traverse, sealed cartridge bearings, 15mm thru-axle, 110mm spacing, 24h
REAR HUB: Roval Traverse SL, DT Swiss Star Ratchet, 54t engagement, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
INNER TUBES: Tubeless
SPOKES: DT Swiss Revolution
RIMS: Roval Traverse SL 29", hookless carbon, 30mm inner width, 24/28h, tubeless ready, hand-built
FRONT TIRE: Maxxis DHF 29 x 2.5
REAR TIRE: Maxxis DHF 29 x 2.5
COCKPIT
SADDLE: Body Geometry Henge Expert, hollow Ti rails, 143mm
SEATPOST: Bike Yoke Revive 185mm
STEM: Syntace F109, 6-degree rise, 31.8mm clamp
HANDLEBARS: Specialized Trail, FACT carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm, 31.8mm
GRIPS: Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
BRAKES
FRONT BRAKE
SRAM Code RSC, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKE: SRAM Code RSC, 4-piston caliper, hydraulic disc, 200mm
ACCESSORIES
PEDALS: Specialized Platform, Cr-Mo axle
FRAMESET
SEAT BINDER: Alloy, 34.9mm, titanium bolt
FORK: Öhlins RXF 36, 29/6Fattie, Twin-Tube design, air spring w/ adjustable 3rd chamber, adjustable high and low speed compression, adjustable rebound, 15x110mm thru-axle, 51mm offset, 150mm of travel
FRAME: S-Works FACT 11m carbon, 6Fattie/29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post IR routing, 148mm spacing, fully sealed cartridge bearings, 135mm of travel
E-BIKE
UI/REMOTE: Trail Handlebar Remote, motor mode switch & walk-assist
BATTERY: Specialized M1-504, integrated Trail Display, ANT+/Bluetooth® module, 504Wh, Mission Control App connectivity
CHARGER: Custom charger, 42V4A w/ Rosenberger plug
MOTOR: Specialized 1.3, custom Rx Trail-tuned motor, 250W Nominal
WIRING HARNESS: Custom Specialized wiring harness
